Question about Samsung LN-S4692D 46 in. LCD HDTV
I want to replace four capicitors in my Samsung LCD TV
Is it ok to replace 10v 1000uF Capacitors with 35v 1000uF capaticors
  • 905 Answers
Yes that is ok to upgrade to the 35v 1000uf cap
Posted on Jan 04, 2009
My 32 inch Samsung lcd will not turn on.
This is related to 3-4 1000uF 10v capacitors that need replaced with 1000uF 35v high temp capacitors. These broken caps are placed too near a heatsink for transistors and have blown due to the high temperature.
Replace those and you'll be running again!
THANKS
Mar 07, 2011 | Samsung LN32A330 32 in. LCD TV
I am having problems with my Samsung lcd tv. Whe i try to switch it on I have a clicking sound and the red led power light flashes the the tv goes off. Can you give me an answer to resolve this problem
Your problem is typical of Samsung LCD TVs. The capacitors on one of the internal boards are rated at 10V and should be higher. If you open the case, you'll see bulging capacitors. If you can handle a screwdriver and soldering iron, you can actually fix it yourself with a few capacitors from an electrical supply store. Simply read the specs off the bulging capacitors and get a higher voltage-rated replacement. For exmaple, if the capacitors say "1000uf 10V 105C", you would replace them with "1000uf 35V 105C" or similar rating. Or an easier method: Recently, Samsung themselves have been making repairs as it is such a widespread problem. Call Samsung at 1-800-726-7864 and they may just repair it for free, even if its not under warranty.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
Feb 21, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
When i turn my samsung tv on no picture comes up or any sound other than a clicking sound from the back of it somewhere near the top left of the tv,. could this be the capacitors?
No
The clicking is the power relays coming on.
Do you get a flashing power light on front ?
you will need to have it serviced.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Not turning on at all
check your power supply. remove it then remove the metal plates on top of the psu. ill bet you find 2x 1000uf 35V ,4 x 1000uf 10V and 3x 670uf 35V capacitors that are swollen or leaking. if you replace the 1000uf caps it will work but if the 670uf caps are swollen as well its a good idea to replace them as well. the 1000uf capacitors can be bought at radio shack for around 10 dollars. you can use the 1000uf 35V caps for the 1000uf 10V caps if you cant find the 10V ones . the 35V caps are a little bit bigger but still work . you will need a good soldering iron (35-60 watts) and a good desoldering tool . easy to do if you know how to solder.
Jun 29, 2010 | TruTech PLV16320 Television
My Samsung PS4297HD TV started to turn itself off after about 5 minutes and noe wont turn on at all but just makes a constant clicking sound
Hi
A common fault with this model is bad capacitors in the power supply, Remove the back from your tv and look at the power supply for bulged / swollon capacitors on top, they may even leak a brown like substance and should have a value of around 1000uf 10v
Change these where possible with the same uf but higher voltage lets say 1000uf 25/35v
Hope this helps
Please rate my reply++++
Apr 05, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Clicking sounds and delay when turning on lcd tv LE52M86BD
Hi
Hope this helps
Jan 09, 2010 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
ILO LCT32HA36 will not power on
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Aug 24, 2008 | iLO LCT32HA36 Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
341 people viewed this question
Jerry Greenberg
Jerry Greenberg
