Question about AEG Washing Machines
E10 on Lavamat 64680
The machine ends prematurely - sets itself to 0 when there is still more than an hour to go. Door sign is red - opens only after changing the program again. The laundry is too wet then. After trying Soak/Prewash + Three/Four to the left - testmode (?) - I got the Errorcode 10 - checked the water but it seems to be fine.
SOURCE: Errorcode C3
your merchine as over filled with water take back off and clear out water
Posted on Mar 22, 2007
  • 8 Answers
SOURCE: Prewash flashing and machine Overfilling
Their is a small bowl connected by a see trough plastic pipe leading up to the preshour switch, that you will have to clean out the bowl and disconect the pipe from the presure switch and blow trough this to clean out any droplets of water. Replace then try the machine again, it may fill up again, dont dispair, empty the machine and re-blow trough the hose again with it disconected from the preshure switch. To empty the machine of water place the outlet hose into a bucket 3 or 4 times.
slimjim1
Posted on Nov 26, 2007
aborcass
  • 2651 Answers
SOURCE: Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Posted on Oct 31, 2008
SOURCE: can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
Posted on Nov 20, 2008
SOURCE: drying
The E10 error code means - not filling water.
The problem could be because of clogged filters on the water inlet line or a malfunction inlet valve.
Also there is still some water inside accumulated so please do check the filter for blockages.To avoid other errors check the outlet valve and the filter as a precaution.
Good luck with the machine.Please do rate my solution.Also do post comments for further help if needed.
Posted on Apr 12, 2009
Hi. I've got samsung eco bubble washer dryer. At The end of the cycle it won't swatch off by itself but it's showing 0 plus red light with drum on it.
if you turn off at wall and open door are the clothes really wet ? and water in the bottom of the drum ?. if so it can be a blocked filter or the pump is not working at full working order/ or the drain pipe is blocked/trapped. there is no code 0, can you try a load without anything in the machine and see if it works properly.if it does it can be a fault with its weight adjuster this is controlled by its motor, at start it turns the drum a few times slowly to check weight and then will give you a time to end of wash this could be the 0 as in 0 time left. you should hear a click to say the door is open. if no click it could be sticking or the pipe that feds it is blocked, if the pipe is blocked it will click and door not open. try it on a short wash lowest setting can use this setting to use a cleaner in the system while its empty. try these and come back if the problem is not solved.
Jan 21, 2017 | Samsung Washing Machines
WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
What does E10 mean? is this an error
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
Jun 17, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG LAVAMAT 75520 door light doesn't switch to green
untitled-rq2y3fnvghvfrpvxa33jafnd-5-1.jpg After turn and choose cycle by program switch, press the Start / Pause button otherwise the program will not start.
If you did everything right then the "Cd" should appear on the display, which means door lock failure.
green = The door can be opened
av = The door can not be opened at the moment
red = Door is open
Dado
Apr 01, 2017 | AEG Lavamat 72640 Front Load Washer
Lavamat washine machine door won't unlock after wash
You have to wait for a few minutes to be able to open the door.
Dec 11, 2009 | Washing Machines
AEG Lavamat 6250 - opening door?
Try spoon handle gently prise open
Nov 12, 2009 | Washing Machines
My aeg lavamat 16810 washer dryer won't dry. The error message is E10, meaning the water isn't going in. Water is running until the dryer kicks in, then the valve closes and it stops. The heater etc are...
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Oct 28, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E10 PROPLEM AEG
Your Machine manual is HERE
E10 is an inlet fault.
Check the water valve is turned on. If you are only getting a dribble of water in, then clean the inline filter at the hose inlet.
If no sound of inlet water - replace inlet valve (available as a spare from online stores)
Sep 30, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Operating instructions lavamat 538
type in ' AEG lavamat 538 ' into the top right hand address bar on your pc and you will find links that will give you all the instruction manuals you need... AEG is at the lower end of the list....
Good luck
sue
Aug 03, 2008 | Washing Machines
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
26 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
