Question about Canon CanoScan 9950F Flatbed Scanner
Scanner Glass Smashed
Hi
My Canoscan 9950f Flatbed Scanner glass has been smashed..... Is that the end of the road for it or can it be fixed?
    President:
  • 2,976 Answers
Scanners MUST have glass inthem. Different types of plastics will give different refractive problems. Plexiglass is acrylic. Polycarvonate (Lexan) will give different results.
Posted on Jan 05, 2009
    President:
  • 846 Answers
More than likely yes, unless you like to mod things than perhaps you could replace it with plexi glass. Could not promise it wouldn't even work after that but would also take time and know how.
Posted on Jan 04, 2009
  • Quickfx PC Repair Jan 05, 2009
    Very good point I did not think about that Fixer1950...
2 Suggested Answers
SOURCE: Hi My Canoscan 9950f flatbed
note for CWM!! send me a PM at bcbuy@sbcglobal.net regarding availability of 35mm film guide from your broken 9950F. thanks bc
Posted on Aug 24, 2009
Canot get the canoscan 9950f to work on windows 7
Hello you can download the driver here:
http://software.canon-europe.com/products/0010135.asp
Make sure you download the right software for your system
32 or 64 bit.
Good luck
Oct 14, 2012 | Canon CanoScan 9950F Flatbed Scanner
How do you clean under the glass of the Canoscan 4200f
I have a Canon 4200F, and you can refer to this one I have already answered:
http://www.fixya.com/support/t19119519-clean_inside_glass
Have a good day
GB
Oct 09, 2012 | Canon CanoScan 4200F Flatbed Scanner
How to pick off glass of canoscan 9950F I want to clean the dirt on the lamp and the inner side of glass please HELP
Unplug power source.
Disconnect cable connecting the lid to the base.
Remove the lid by pulling straight up.
Using a phillips head screwdriver, remove the two screws that can now be seen at the bottom of the slots into which the lid hinges were inserted.
Starting near the hinge slots, pry the black plastic frame up and away from the gray plastic body.
Slide the glass panel and its gray plastic frame towards the back of the scanner and lift off.
Jul 10, 2009 | Canon CanoScan 9950F Flatbed Scanner
How to clean lamp
Make certain that the scanner is not only turned off, but unplugged. And disconnected from the computer.
Then gently lift the glass off - the glass on which youy place whatever you want to scan.
Once the glass is off, you can clean both sides of the glass, but remember which side was facing up.
Also, if the bulb inside is truly dirty, you can gently clean the bulb.
Replace the glass cover, and reverse your procedure.
Plug it in, turn it on, connect it up again, and try it. It should solve your problems.
-a.
Jul 02, 2009 | Canon CanoScan 9950F Flatbed Scanner
Canoscan 9950F scanner will not scan with Win XP
Since you have had the scanner a while, you may not have a recent enough driver to work well with XP: until I smashed my 9950F, I was scanning under XP with the ScanGear CS 10.324a driver with no problems (the driver is dated 22 June 2007). You can download it from several sources on the web, I used
"http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=10446#DownloadDetailAct"
Other than that, they report some issues if the system drive is NTFS, but I was using NTFS for my system (and only) drive, so I don't see any reason for this to be your problem.
Good luck,
CWM
Mar 19, 2009 | Canon CanoScan 9950F Flatbed Scanner
Hi My Canoscan 9950f flatbed scanner glass has been smashed........ Is that the end of the road for it?? Or can it be fixed?
I had the same problem, shipping the scanner from Olympia, WA, to Austin, TX, the main glass broke (the sheet of glass you see when you open the scanner lid when it is set to scan an opaque object like an 8x10). I ordered a replacement part from the Canon parts center in New Jersey (732-521-7230) and at the time she told me there were only two left in the country, so you might be able to get the last one.
To replace it you just need to lift off the scanner cover, remove one scree in the bottom of each of the two wells the cover posts fit into, and lift the dark plastic part on the back of the scanner up (I think there are a couple of plastic snaps on the back side but they are not easily broken. Just pull up uniformly on both sides. Then you can remove the broken glass and put the new sheet in (align the plastic guides on the new sheet just like the ones on the old one were aligned).
Unfortunately, my scanner still doesn't work -- so I may have to give up on it. It seems stuck on a fairly well known failure code (2,178,0) when I start to scan and Canon customer support says there are no authorized service centers for the 9950F (I wonder if all their scanners are not repairable?).
Jan 04, 2009 | Canon CanoScan 9950F Flatbed Scanner
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Install CanoScan 9950F Driver
I found the answer to the 9950F VISTA driver - I went onto Canon's site and downloaded the VISTA driver - AND - the toolbox. Then a reboot and this time Vista recognised the 9950F.
Sep 15, 2008 | Canon CanoScan 9950F Flatbed Scanner
Opening Canoscan case
screws on bottom ease the case off fix ribbon there under the rubber stops then once open your going to want to seal galss back down i recommend jb weld on edges to hold glass in if u dont secure glass when open a month down the road the glass will pop down i had my scanner 16 years since jb welding the glass down you only spot jb weld the glass though
May 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan 9950f red line on scan
Try running a calibration. This is done thorugh ScanGear in Advanced mode. Once in Advanced Mode, in the Image Settings section there should be an option for Calibration (you may have to scroll down in this section to see it). After running the calibration, try performing a preview scan with nothing on the scanner glass. If the red line shows up on the preview now, then most likely the scanner needs to be serviced.
Mar 12, 2008 | Canon CanoScan 9950F Flatbed Scanner
Canon CanoScan 9950F Flatbed Scanner Logo
159 people viewed this question
old marine
old marine
