Get "no registry key" when I try to run the installation cd
I cannot run my cd installation. It stops running and says that there is no registry key
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
I installed Win7 on my desktop, then I can't see my DVD-ROM drive and when I insert a CD/DVD it doesn't read. How can I resolve this problem. I hope you can help me. Thanks!
First make sue that both connection connected properly to cd dvd rom inside cpu.Both ide and power cable. Also check in bios that cd dvd rom recognized. If it recognized in bios but not in windows then follow below. For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall cd rom drivers then it automatic install drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Aug 27, 2011 | Computers & Internet
My Dell CD burner stopped working and I need it to work
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
Jun 19, 2011 | Dell Computers & Internet
Why my computer didn't detect my CD-ROM after I reformat my computer there is no icon in My Computer but if I press the eject button it eject or it was function but didn't read a CD ??
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall cd/dvd driver then it automatic install it's drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Oct 05, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
Computer comes up with a code 41 error, can't play CD/DVDs music or downloads
This error comes because of cd/dvd registry changes. For that you need to delete some keys with below method.then this error will be fixed. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Jul 10, 2010 | Lite On LiteOn 16X/40X ATAPI DVD BLACK ROM...
Dell optiplex 280 dvdrw drive not regonized
It may be a registry issue .Try following steps but remember take a backup of your registry (upper filter & lower filter)
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Preventing System Errors
To prevent frequent system errors on your system, you must take care of the following:
  • Be a vigilant and aware user by being careful about the websites you visit and the email attachments you open.
  • Do not visit dubious websites and do not open attachments that come with unsolicited mails.
  • Implement antivirus and antispyware programs on your system, keep them updated, and run them regularly to prevent any malware infestation on your PC.
  • Keep your operating system, device drivers, and installed applications updated with the latest patches and security updates released by their manufacturers.
  • Use system utilities included with your Windows system to perform regular system maintenance.
Mar 22, 2010 | Computers & Internet
HP Deskjet D2360
First, try running the installation as Administrator. Right click on the executable and select Run as Administrator. If that doesn't work, go to that registry entry and make sure that System and Administrators have Full Permissions.
Mar 26, 2017 | HP Deskjet D2360 InkJet Printer
Initializing error :registry value is not of binary type
First of all, its AVG, not AGV. Now the solution.
You may be trying to install AVG when you have already one antivirus program running. OR you had once installed AVG sometimes in the past, but uninstallation was not properly done. Hence it is showing registry key error.
1. If you are running any anitvirus prog now, first uninstall it. Then restart the machine.
2. Now you try install AVG. it should install. if not, try the following
Go to system restore and create restore point for safety.
go to run and type regedit and then enter
Press cntrl + F for finding earlier registry keys of AVG. Try to find out all old registry keys amd delete them all.
Restart the machine. Its DONE.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
Satellite A205 help "loading DVD"
Have you tried other discs? Does it read CD or recognize blank discs? Have you tried a bootable disc to see if it reads prior to Windows loading?
If the drive doesn't appear in My Computer this is a possible fix:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 19, 2008 | Toshiba Computers & Internet
My cd player stopped working says I don't have the drive any more
Try this, but note this involves editing the Windows registry and the key must match exactly and be edited only as described. If you are not comfortable with this procedure, then do not do it - ask someone for assistance.
Reboot.
Dec 07, 2008 | Dell Dimension 3000® Pentium® 4...
Cd/dvd driver
Exit and close all applications currently running on your PC.On
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
LowerFilters
UpperFilters
that should fix it.
Aug 25, 2008 | E-Machines eMachines Desktop PC
jasbo
jasbo
