Question about Nikon D80 Digital Camera with 18-135mm Lens
Shutter making an extra clicking noise
I just recently starting getting an extra clicking noise when my shutter closes. If I open it for a longer time than 3secs it click in between taking shots. How can this be fixed? Thanks for any help.
    Novelist:
  • 121 Answers
Timndege,
You are taking long exposures over 3 seconds, the camera does make some slight noise while the timer is going through the count down, that is normal, as long as the shutter is doing what it is supposed to do and your image is coming out (and the ones over 3 seconds also) it sounds normal. Only if it is hanging up and taking longer than the time you are describing, then the shutter should be cleaned.
randy320sgi
Posted on Jan 06, 2009
I recently put air flow in my 2010 1500 ram
i do not know what air flow is, but i know that the popping noise is the electronic vents opening or closing depends of the hot or cold selector. could be a vent not seated correctly or some obstruction keeping vents from opening or closing all the way
Sep 09, 2014 | 2010 Dodge Ram Pickup 1500
I took a picture in the s mode or any mode messing with the shutter speed and when i go to view the picture i just get a black screen.....i am not sure why this is happening....any thoughts?
Proper exposure is a balancing act between the shutter speed and the aperture (the size of the opening in the lens). (There's also the ISO sensitivity, but I'll ignore that for now.) If the shutter is open for a longer time, the lens must be closed down. If the shutter is open for a shorter time, the lens must be opened up wider to allow the same amount of light to reach the sensor.
The Shutter priority mode attempts to adjust the aperture to give the proper exposure for the shutter speed you've selected. The lens has physical limits as to how wide the opening can be. If the shutter speed is too fast, the lens will only open as far as it can go but that may not be enough. In this case the camera will display "Lo" in the viewfinder to warn you but will go ahead and take the picture anyway. If the shutter speed is too fast then you won't get enough light through the lens and you'll end up with a dark or black picture.
Try reducing the shutter speed (leaving it open for a longer time), like 1/30 of a second instead of 1/125 of a second. If the shutter is open too long, you run the risk of camera motion. You can also increase the ISO setting, making the sensor more sensitive to light. This increases digital noise, which looks somewhat like film grain. You can also try adding more light, perhaps by using the flash, if the subject isn't too far from the camera.
Dec 18, 2010 | Nikon D3100 Digital Camera
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
2001 chevy blazer sunroof is open and won't close
most of the time on those sun roofs when you hear the clicking noise coming from the headliner when trying to open or close your sunroof and you have to help it move that clicking is the gear in the motor skipping ,I just fixed one on an infinity the other day that was doing the same thing ,the plastic gear gets worn down and will not grab any longer ,hope this helps!
Aug 06, 2009 | 2000 Chevrolet Blazer
Toilet trouble
Based on the phrasing of your question, I'm thinking that the bad noise happens for the first time when the valve opens to start filling (this happens when you first let water into the bowl) and then again when the valve closes (when the cistern is full). Valves sometimes have a high-pitched squealing noise when it takes a long time to open or close this valve. Sometimes, you can make it go away by turning the screw to adjust the height that the ball/float has to be in order to shut off the water (the more horizontal, the longer it takes to shut off the flow, and the longer the noise continues). Sometimes, this is just caused by an aging mechanism and it turns out to be quicker and easier to just replace that part of the toilet (they make replacement kits that are very inexpensive and easy to install).
Jul 10, 2009 | American Standard Home
Problem w/ Nikon D40...Help Plz *_*
check your camera's shutter speed then try shooting again. set it to different modes, try manual, increase the shutter speed to 80. don't use flash shoot in daylight. try that first... see if its still blurred. hit me back on the results.
Apr 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The camera shutter is always open
Plecs can you send me k750i Camera solution (with photos)
Oct 28, 2008 | Sony Ericsson K750
Clicking noise and shutter wont open
Look for Contamination on the slide Take Denatured Alcahol and Clean the Assembely Let me Know ttech
Jul 20, 2007 | Nikon Coolpix 3200 Digital Camera
Blurred images with no flash
First, try to get more light, particularly natural light (window); second, try using shutter priority (S mode), setting the shutter speed at not less than 1/50, faster if you are shooting motion/action (check the Properties of the blurred pictures that you've been getting in Camedia software - the shutter speeds are probably too slow because of the low light), and experiment with higher ISO settings (either 200 or Auto, not 400) though there's a trade-off in noise levels.
Sep 11, 2005 | Olympus Camedia C-3020 Zoom Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
98 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
