Question about Mitsubishi WS-48613 48" Rear Projection Television
My tv wont turn on??!!
I have the Mitsubishi Ws 48613 and the power light blinks for days. It wont turn on for any reason??!! What do I do. The reset button doesnt do any thing but turn of the flashing light??!! After I let go of the reset button it comes back on??!!
  • cbgerber Feb 11, 2009
    I have the same problem with my Mitsubishi Ws 48613...the power light blinks for days. It wont turn on for any reason??!! The reset button doesn't do any thing but turn of the flashing light??!! After I let go of the reset button it comes back on??!!
There are six capacitors on the DM board 1000uF 16 v that go bad, repace them with 680uF 16 v. 105C. the capacitors are clustered together. on the DM board the DM board is the board that is enclosed in the metal box. the repair is not an easy one so have a tech help you. this is a known problem.
Posted on Feb 28, 2009
  • joneies Feb 28, 2009
    take a hairdryer and concentrate air on the left side(looking from the
    back) on the metal encased board(mounts vertical and has a led on it
    inside) for about 2 minutes the led on the board will start to flash
    then go out.,then the led on the front will go out. i then have to push
    the reset button,then the t.v will come on or try using the power button on the front of the tv to turn on
Timer light just blinks. I removed buttons from
A continuously blinking green light is almost always caps on the dm board.If you have access to an esr meter check them that way and replace.
Nov 10, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi ws-48613 no power
It seems problem of weak capacitors in power supply and deflection board.
If you have little experience of TV repair and good soldering skills, then check above said boards for weak capacitors.
You also need to have service manual of WS48613 which can be obtained from Manual Zone.
Service manual has schematics and technical information of TV to help in repair.
Dec 12, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-48613 made in 2003
have not solved it but wanted to reply. do not appreciate your original offer for informatiion and help when all it was an attempt to get one to sign up for and pay for your service. i will seek help from someplace that is not trying to scam me.
May 21, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
Jan 14, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55859 projection tv
how many times does it blink does there seem to be a pattern?
try this:
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 18, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
