Question about Refrigerators
I bought a JH. SA 12645 mini fridge used ...plugged inside my home to 120v. It doesnt seem to cool or get warm. What could the problem be....?
2 Suggested Answers
  • 205 Answers
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Posted on Oct 14, 2009
My daughter bought back a mini amana fridge it seems too hot on the sides and its on 6 os that normal??
Sorry but I don't recognise the fridge brand. The internet suggests these are not the things called mini fridges but in reality are merely coolers so I guess it is a regular fridge designed to keep stuff between 2 and five degrees C.
Not sure what you mean by 6 os.
Conventional fridge design has a thing at the back that looks like a radiator. This condenser is prone to corrosion and is easily damaged resulting in the loss of refrigerant. Since it was decided all types of refrigerant gas is damaging to our atmosphere, manufacturers have been increasingly burying the radiator thing in the fridge casing where it is protected, often at the sides. Usually the condenser will become quite hot until the fridge interior is down to the required temperature when just maintaining the inside temperature it will vary between warm and cold if the door isn't opened much and the insulation and door seal is in good condition.
Burying the condenser(s) in the casing makes them less efficient at losing heat and so they will become hotter than the conventional old-fashioned design during the interior cooling stage..
I hope this helps and little.
May 15, 2016 | Amana Refrigerators
Why are mini fridge sides getting very warm?
that's normal for that refrigerator it takes the heat from inside and place it on the metal outside of the refrigerator
Appliance 911 Sea Breeze
Jul 30, 2015 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
We bought a used but newer model White Westinghouse refrigerator; brought it home, plugged it in. We can hear the condenser motor running, but neither side is getting cold. There is an additional hose of...
Some fridges have an internal fan that sounds like the compressor. If the compressor is running and the fridge is any good the inside will quickly cool and the condenser will become warm. If the outside gets warm but the inside doesn't get cool it is possible the defrost heater is permanently switched on because of a fault.
If the compressor is running and nothing is happening the fridge has probably lost it's refrigerant gas. Moving fridges can upset them and it is unwise to switch on straight away - they really need to settle for at least 4 hours. Switching on too soon can damage a lubricant deprived compressor.
Oct 04, 2017 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Electrolux camping fridge not getting cold when running on gas, warm air flows from top vent bottom vent not blocked please help
Does it work o/k on 120v? If it does then you may only need to have the burner serviced which entails pulling the burner and jet apart and giving it a good clean out. If the fridge heats up on 120v but does not cool, then you have a major problem with the cooling system and can be expensive to repair
Swy
Aug 25, 2008 | Electrolux Refrigerators
Fridge cycling cool to warm
yes, you should not have a gap. It is allowing warm air to circulate in ref.
Jan 17, 2008 | GE GSS20IEM Side by Side Refrigerator
Fridge not cooling compressor works intermitently
Is the brand name of the compressor Tecumseh?? How old is this fridge??
Jan 10, 2008 | Frigidaire FRS26RLECS Side by Side...
Problem with cooling and fan on frige
My boyfriend is in the process of fixing my fridge.  There was ALOT of ice on the back of the inside of freezer and it made it to where the fan wouldnt work.  He is replacing the fan which is super easy  email me at kandj1274@yahoo.com if you need any more help
Apr 20, 2007 | Kenmore 60721 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
