Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
My light on my generac generator is 1/2 green & 1/2 yellow now. It was all green all week. what is the problem? It is still giving me power.
Had green light since it came on Monday and had green light til tonight when I noticed it was half green and half yellow. Looked in my owners manual and nothing tells me about what light indicates. I am afraid I will lose power from the generator as I have no electricity.
  • 26 Answers
SOURCE: how do i flash my generac 5000 power plus generator
its the rotor ,the stater ,voltage regulateor or control board. i fix these everyday. it also just be the brushes.
Posted on Jul 14, 2009
  • 14 Answers
SOURCE: Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
Posted on Oct 01, 2009
Testimonial: "This is good information in the event that the low oil switch is part of the problem."
SOURCE: Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Posted on Jun 20, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Need a Repair Manual for
This manual should have what you need:
http://lawnandgarden.manualsonline.com/manuals/mfg/generac/86640.html
Click the link: The click on the image then wait for popup window... Close popup window click on get this manual.
It is published by Generac
Thanks for choosing FixYa
Kely
Posted on Sep 18, 2010
SOURCE: I have a Generac Guardian
John did you ever get this problem solved because I too am having a similar problem however for me it is also not shutting down automatically when the power is restored
Posted on Dec 11, 2010
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    It will turn over once or twice and stops it has a red light on where the braker panel is
    press the helpful button and follow me on Fixya for more helpful tips
    The current models of automatic standby generators will have LED indicator lights on the side compartment of the generator. A green LED light will indicate that the unit is in AUTO mode and is ready to run, or is running properly during a utility outage. The yellow LED light will indicate that maintenance is needed. The red LED will indicate either that the unit is switched to OFF or that there is an alarm detected. If a yellow or red LED are present, you will need to check the generator's control panel, as it will describe the type of maintenance needed or the alarm present. This information can be found in the owner's manual as well. You can find a copy of the owner's manual online by searching the model or serial number of the unit here
    http://www.generac.com/service-support/product-support-lookup
    Jan 27, 2016 | Generac Guardian 20kW Model : 5875
    Why does it crank and almost start on 1st try?
    Generac Generator Troubleshooting - YouTube
    ? 1:39
    https://www.youtube.com/watch?v=AKN2dc59cxY
    Dec 20, 2013 - Uploaded by Appliance Princess
    I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
    Generac Power Systems - ConsumerAffairs.com
    www.consumeraffairs.com > Homeowners > Utilities
    Rating: 1.3 - ‎26 votes
    Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
    Generac standby generator - Propane - wont start?? - DoItYourself ...
    www.doityourself.com/.../487838-generac-standby-generator-propane-w...
    Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
    141 GENERAC complaints and reviews @ P'ed Consumer
    Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
    How to change the fuel filter on guardian quietpact rv generator
    Dec 05, 2015 | Generac Electrical Supplies
    On our 20 generac a notice came up tat it needed a oiland filter chnge we did thisbut the message is still there hodo we get his message off andmke thhe light on the side go off thanks
    The yellow LED is a maintenance reminder light. To reset a maintenance reminder, press the Enter key on the control panel. The reminders will be displayed at the following intervals.
    "Inspect Battery" 1 Year
    "Change Oil & Filter" 200 hours or 2 years, 100 hours or 2 years on 20kW models
    "Inspect Air Filter" 220 Hours or 2 years
    "Change Air Filter" 200 Hours Or 2 years
    "Inspect Spark Plugs" 220 Hours or 2 years
    "Change spark Plugs" 400 hours or 10 years
    Here are a couple of links
    5875 Resetting maintenance reminder light question Ziller Electric Inc...
    Dec 31, 2014 | Generac Standby Generator - Residential -...
    Green light on unit not lit, no test startups as
    Check the battery condition, and charger. Check also the fuses in the transfer switch (note they are line voltage so maybe call an electrician)
    Oct 26, 2013 | Generac Honeywell 20KW Standby Generator
    Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
    Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
    OVERLOAD LED (red): Lights up if the generator experiences
    a load greater than the rated output, low voltage, overheats or
    the powered circuit experiences a short. The output is stopped
    even though the engine keeps running.
    I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
    Thanks for choosing FixYa.
    Kelly
    Aug 30, 2010 | Kitchen Ranges
    Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
    443 people viewed this question
    Top Generac Electrical Supplies Experts
     Kenneth
    Kenneth
    Ottoniel
    JOHN LAPIER
    Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
