How to open Yamaha RAV247 ? Power system button stopped working.
Does anyone knows how to open yamaha remote RAV247 ? My "power system" button stopped working.
  • 45 Answers
SOURCE: How to open a Phillips remote control???
force it by using a thin-tip flat screwdriver on its side, then to all sides until it will be open.
Posted on May 17, 2007
  • 279 Answers
SOURCE: yamaha RAV250 remote control for my laptop
I believe techman is right about it not working with your laptop.  However, you don't need to contact your computer's manufacturer for information on a remote that will work.
Check out this blog entry:
http://tech.yahoo.com/blog/null/15972
Reviews what looks to be a very nice wireless remote that works with any laptop.
Hope that helps,
Dyllan
Posted on Oct 22, 2007
SOURCE: Openning the Yamaha RAV -206 remote
hey hows it going i also have the same remote.
what youll need is a #4 (small) and remove the two samll screws under the battery's. also you will need a small screw driver (flat head) it would be better if you have two.
what youll need to do is start in thecenter of the remote and slide the screw driver down the side of the remote keep one screw driver in as you slide and pry the remote apart. there are four latch's on the remote on each side (three along remote bottom center and top)
also on each side of the infared light that should be it just repeat the process on the both side and u should be good.
Cullen
Posted on Apr 24, 2008
SOURCE: I can not find the user manual for the yamaha rav 250 anywhere.
Does anyone know where to find a user manual or instructions to use the Yamaha RAV250 remote control?
Posted on Sep 19, 2009
  • 3 Answers
SOURCE: How do I program my universal remote?
Can I suggest maybe instead of trying to program your universal remote control, maybe a better solution is trying to buy the original replacement remote control for your Cyberhome DVD Player. I've been down this road before and eventually you'll be faced with not being able to find the solution and not left many other options. I went to http://www.everytvremote.com to buy a cheap replacement remote for my tv and got it within a week and didn't have to worry about programming the universal remote ever again!
Posted on Dec 22, 2009
Yamaha wc55280 power button does not work
Sounds your remote need cleaning. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
One among its posts have details about how to clean a remote control.
Apr 27, 2014 | Yamaha New Original WC55280 Remote Control
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Yamaha YSP1
We have the same issue. I owned the unit for about 2 1/2 years before it quit working. The Yamaha YSP-1 has been sitting on my shelf for the last 2 years now collecting dust. If anyone finds a solution, please let me know
Dec 22, 2008 | Yamaha YSP-1 System
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
Jun 28, 2017 | Yamaha Audio Players & Recorders
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
