most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
This is usually caused by 2 things
IF your mower had a primer bulb that bulb has a hole in it or there is debris in the bottom of the fuel float bowl that has blocked the main fuen jet. The remedy is to remove the float bowl and clean out the bowl, bowl nut and the main fuel jet in the threaded area of the bowl nut with CARBURETOR CLEANER. If your mower has a primer bulb the bulb will most likely need replaced. Since you did not include a make and model number this is a horribly generic and somewhat unprofessional response. You left me little option but to respond as best I could at this time. If you respond with a make and model number I can provide the steps you should take to perform a DIY repair.
Thanks for choosing FixYa,
Kelly
The part you are after is called a starter pawl, i know because the same thing happened to mine. Unfortunately you can't buy just the pawl, they only sell a flywheel kit which is about $35 which contains the flywheel and two pawls.
Hi there... Electric chainsaws only use bar and chain oil. If you go to a hardware store or garden power tool outlet, you will find bottles of bar/chain oil. That is all you need. Just fill the reservoir up and top up as needed. Any decent brand will work well.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can I find a replacement primer bulb fuel cap?
