Maytag HYE3658AY Electric Dryer
Problem for Maytag HYE3658AY Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
By Shinecatcher on Jan 04, 2009
My Maytag Performa Pye2000ayw won't turn on suddenly. I unclogged the vent (yes, it appeared clogged). Taped the 2 wires to the thermal switch together (above the element), and plugged it back in. Still doesn't work. Checked online for more help, but not sure what's next. If the thermal fuse is blown, will taping the two wires together really turn it on? The wires are pinched together with a flat ending so they don't really interconnect--just taped them flat together. The dryer has not been performing well for over a year--dry cycle is about 1 hour. Never overheated. My husband said the last time he dried clothes it took even longer to dry. I don't know if the heat was on or not. Will the element stop the dryer from turning on, too?
Comments:
Jan 05, 2009
- I taped together two red wires for the blue top what I think is the thermal switch. Another comment said if you do this to the thermal switch you can see if the dryer will start again and if it does, then you replace the switch and fuse. Maybe I should tape together the two white wires that go to the fuse instead. I'm a bit confused.
Jan 05, 2009
- Thank you. I tied the wrong wires together. Tied the fuse wires together and it works, except the heater element was really hot. I did blow a lot of dust around though. Will my element go out if I use the dryer like this until I can replace the fuse?
Best Solution
posted on Jan 04, 2009
Very Helpful)
jtbjtb
Rank: Guru
Rating: 89%, 60 votes
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Comments:
Jan 05, 2009
- All I can tell you is that the thermal fuse is on the exit chute, and yes, if bypassed the dryer may run, proving it is bad.
Jan 05, 2009
- Probably if is too hot. That means you thermostat need replacement as well. Maytag makes a kit for this, part # LA1053, available for $14.99 at timerking.com . Hope this helps!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 16, 2009
Not Rated)
shinecatc411
Rank: Apprentice
Rating: 0%, 0 votes
Thank you! It worked. Purchased the thermal limiter switch/thermostat kit locally super cheap--the appliance company delivered it to my doorstep and I'm installing it! Wow! You were great!
Was this helpful?
Yes
No
Popular Solutions for Maytag HYE3658AY Electric
Questions and Unsolved Problems for Maytag HYE3658AY Electric
Do you recommend Maytag HYE3658AY Electric Dryer?
Answer
Answer
my maytag dryer wont start and the drum light doesnt work anymore. what is the problem? dryer is... (More)
Answer
where are the thermostats located on this dryer?
Answer
Hi! I have a Maytag HYE3658AY and it shut off in the middle of a load of laundry with no warning. We... (More)
Answer
I replaced the element to find that it was not bad , so I replaced the thermostat on the element... (More)
Answer
My dryer is not working, when i tryied to turn it on. I got it zapped me. I looked for burnt wires... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag HYE3658AY Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
