Question about Amana AEW4530DDS Electric Single Oven
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Hello, my Amana convection oven's control panel works on only about 50% of the buttons. I assume I must replace the panel is this correct? thanks Jeff
  • Anonymous May 11, 2008
    started and restarted oven but no luck it still doesn't work
  • Anonymous Nov 20, 2008
    The keypads only work for a few months. I have already replaced it 4 times and am now awaiting the 5th. Fortunately I bought the extended warranty so it's free. Why does this keep happening?
  • 3 Answers
Have had the same trouble with this oven. The control pad starts beeping, and I have had an error code F1, and others. I have replaced this panel once before. I saw an internet site that said it was the control pad being mounted to closely to the metal housing, and it actually has a hole worn in it from where the metal rubs on the pad. I took the pad out, and actually peeled the plastic cover off of the control board, and wiped all the contacts with alcohol. No idea why, but that fixed it....I carefully placed the sticky cover back on the control board, and re-installed. It is scary peeling that plastic skin off, but t will come off if you go slow.
Posted on Jan 23, 2012
  • 87 Answers
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
Posted on Jun 08, 2007
SOURCE:
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
Amana AEW4530DDS cancel button the only button to beep or work on control panel. Time of day lights up. oven wont work . before oven went t/u had it on broil with the door open a bit. did this fry the...
A qualified technician needs to troubleshoot the unit and determine if the bubble-keypad has broken or the control board that 'controls' it. The control board would be my guess, and would also cost the most.
Mar 16, 2010 | Amana AEW4530DDS Electric Single Oven
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Amana Convection Oven - Beeping Continuously
F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same. 1_23_2012_2_51_28_pm.jpg
Aug 22, 2006 | Amana AEW3530DD Electric Single Oven
Amana AEW4530DDS Electric Single Oven Logo
321 people viewed this question
Top Amana Ovens Experts
Steve Allison
Steve Allison
Sal De
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
