Question about Sony KV-32S42 32" TV
Beko stuck on standby
Help tv stuck on standby I moved the TV from one room to another. Now when I turm it on the stsndby light blinks and nothing else happens.
  • Sony Master
  • 5,568 Answers
There is a good chance that the power supply in your set was only operating in a marginal manner and taking the AC away and reapplying it can't get the supply to start up again. Old style 'linear' power supplies were less efficient but also less complex and les liekly to fail. The power supply in your set is almost certainly the later type called a 'switched mode' supply.  These convert AC inputs into DC, then with a higher frequency (50-100 kHz) circuit back into AC and finally into several DC voltages that supply the various circuits. Although the path seems convoluted, this results in higher efficiency and, if very high quality components are used, a durable supply. Unfortunately, most companies cheat on certain components resulting in a power supply that is prone to failure.
I doubt that the power supply is on a separate board in that set as one finds in the flat panel units so the whole board needs to be removed for  service; something I generally don't recommend on CRT sets.
In other words, you need to find a surviving TV repair. This I do recommend and I suggest you check the number of complaints regarding all later types of sets; projection, plasma and LCD. The quality of even name brand sets seems very poor and too many people have sets barely out of warranty that are sick.
Posted on Jan 04, 2009
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
Moved TV to a different room and the TV power button is blinking like it is in "standby" mode. How do I get it off "standby" mode??????
unplug it for about 30 mins it will reset it. if that doesnt work it will be stuck in standby mode until a video source is activated. if you are using hdmi both the tv and the hdmi device must be on. (hdcp compliant devices must be turned on at the same time otherwise it will say stuck in stand by mode they do this to prevent people from trying to rip content off hdmi and blu rays had the same issue with my tv and xbox.
Mar 14, 2011 | Televison & Video
32" beko TV stuck in standby
Ur power board is dead.U need a new one.
Jun 21, 2009 | Beko 324250WN 28" TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv model KP53V25
After movement things to try; 1) make sure a/c outlet is working, try with lamp, notice bulb brightness. 2) disconnect all cables from tv 3) unplug tv from a/c out let for 2-3 minutes plug back in. 4) still no work? count blinking of light; eg two blinks slight pause six blinks= fault code 26. Repost.
Feb 22, 2008 | Televison & Video
get a new tv they cost like $500
Dec 15, 2007 | Sony KV-32S42 32" TV
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
