Need help bad!!!!
I need a website that can show me a diagram on the inside of the furnance for a intertherm model number e2eb-012ha. wiring diagram for the trnsformer and seqencer...
  • Heating & Co... Master
  • 1,623 Answers
A sequencer is exactly like a light switch. One hot wire being "broken" by the switch/sequencer. Only difference is its not your finger closing/turning on the switch, it is the low voltage wire from tstat along with a low voltage common. Essentially "c" leg from 240 side of transformer goes to one side of element and the "240" leg of 240 side goes through the sequencer then through a limit switch then to other side of element. Thus delivering 240 volts / 120 to each side of element, bringing on heater. An element is always hot with 120 volts straight off transformer, when sequencer "turns on/closes" an additional 120 volts is delivered... amount needed for the element to heat. Good luck
Posted on Feb 24, 2017
  • 30 Answers
Try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Posted on Jan 05, 2009
Will Honeywell digital thermostat work with Intertherm E2Eb 012HA
Probably, but it depends on the particular Honeywell thermostat that you have.
Oct 31, 2013 | Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
Where can I find a wiring diagram for a interrherm
Hi; Call Your local mobile home supply house and they can tell You how to or fax You the Info. Also the equipment will have the wiring diagrams glued to the inside covers of the outdoor unit as well the indoor unit cover. Power down the indoor unit before removing the indoor electrical cover for the schematics. Do You not have a user or install manual. Call your local mobile home supply house they can often help.. Be care full You get more bees with honey so be very nize...alpharome416
Feb 19, 2010 | Intertherm P3RA-036K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
I need to find the wiring diagram for a intertherm furnance e2eh-012ha
Here is the manufature link. They will email you the manual directly.
http://www.intertherm.net/
Aug 18, 2009 | Heating & Cooling
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
Froze on the cooling cycle and will now not even turn on
If your AC froze up that is usually a dirty filter or coil, blower not running at proper speed or at all, or low on refrigerant. Since you say it won't come on at all now, that's probably an indication that you are low on charge and now you don't have enough pressure or refrigerant to close the low pressure switch. You will need to have the refrigerant charge checked.
May 07, 2009 | Intertherm P3RA-042K Air Conditioner
Heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Need help hooking the right colored prong wires onto my sequencer
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Nov 13, 2008 | Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
466 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
