Question about Peavey Kb2 1x10' Keyboard Amplifier
I need to change the fuse in my Peavey KB2 keyboard amplifier and I can't work out how to remove the back panel to get to the fuse.
    Top Expert:
  • Peavey Master
  • 3,107 Answers
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Posted on Jan 20, 2015
4 Suggested Answers
SOURCE: Peavey KB 100 Keyboard Amplifier How to remove chassis?
I figured this out myself. I was just babying it too much. Some tolex had bunched up between the metal chassis and the cabinet making it feel like it was caught on something. I used a flat edge screwdriver to flatten out the tolex, and then I was able to pull the chassis out the back of the cabinet.
Posted on May 18, 2009
SOURCE: kb2 amplifier stops on high volume and
only twitter is working
Posted on Feb 15, 2011
  • 140 Answers
SOURCE: No sound will come out
It sounds like to me that you blew the speaker. We here at Pro Line Music are Peavey dealers. If you can not check for continuity of the speaker you can bring or send it in. 215-736-8055
Posted on May 27, 2011
Screams loudly when turned on. Knobs at o, nothing connected to it.
How long have you had the KB2?
These are hardware problems. There may be broken solder joints, connections to ground loose / broken, the power-amp circuit (LM3886) is damaged etc. Check carefully. Disconnect the electrical contacts before checking out. Reflowing all of the solder joints.25897496-xykdzr1cdriwl1tmr4ngy0qt-3-0.jpg
Oct 07, 2015 | Peavey Kb2 1x10' Keyboard Amplifier
Looking for the fuse location on a Peavey KB2 amp.??
Best to contact Peavey support. Here is their Support page-
Peavey com
Feb 26, 2015 | Peavey Music
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
Where 's the fuse for my kb 100/200 watt amplifier
The fuse is INSIDE the unit and if it blows, then there are other damaged components that require going to a repair shop to repair before replacing the fuse.
Aug 14, 2011 | Peavey Electronics Peavey PR15D 15" 200...
I have a kb 100.sometimes when i plug guitar in,the volume is really low.if i wiggle the jack it will come back to normal.i thought i might of been the inputs,till i pluged a microphone in(different...
The solder at the connector may be broken loose or a circuit board could have a crack OR the jack may be broken... this is a common problem because the users trip over cables yanking the jack sideways. Take in for repair if you are not electronically adept.
Jul 20, 2011 | Peavey Kb2 1x10' Keyboard Amplifier
No sound will come out of the speaker. I plug in the headphones and there's sound coming out of there, but nothing out of the speaker. It's a brand new amp. I just got it tonight. why can't i...
May 27, 2011 | Peavey Kb2 Keyboard Amp 40 Watts New +20ft...
Im trying to connect a peavey kb300 with a mackie micro series 1402-VLZ 14 channel mic/line mixer
The mixer is stereo and the amp is mono. The line level out of the mixer MAY overwhelm the KB2 regular inputs so try running the mixer into the PA input jack.
Apr 27, 2011 | Peavey Kb 2 Keyboard Amplifier
Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Jul 24, 2010 | Peavey Kb2 1x10' Keyboard Amplifier
May 17, 2009 | Peavey Music
Peavey Kb2 1x10' Keyboard Amplifier Logo
97 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
