Question about Garden
My snapper lawn mower #7800896 won't start after the fresh start fell into the gas tank, I had to tip it upside down to get it out. Please help!!!
5 Suggested Answers
heres2maine
  • 84 Answers
SOURCE: I have a Snapper Briggs & Stratton lawn mower
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Posted on Apr 15, 2010
  • 6468 Answers
SOURCE: how to add oil to snapper lawn mower
if there is no dip stick then look about a inch above the base of the engine for a plastic screw about 1/2'' in dia
Posted on May 29, 2012
SOURCE: Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Posted on Jun 30, 2012
  • 747 Answers
SOURCE: Have a 4.0 quattro Briggs and Stratton lawn mower.
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Posted on Jul 30, 2012
AFTER RUNNING OUT OF GAS, THE MOWER WONT START
Neal, If lawn mower does not start after running out of gas, change fuel filter if equipped, chances are the carburetor has gotten clogged with sediment/dirt from bottom of tank. Remove carb. and disassemble, clean/rebuild. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
REPAIR BRIGGS STRATTON LAWNMOWER TUNE UP CARBURETOR CLEAN
How to clean out the carb on small engine
WelcomeLawnmower Man FREE Lawn Mower andSmall Engine Repair Help
Lawn Mower Won Start
Jul 25, 2016 | Garden
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
The mower won't start
Rocky , start by replacing spark plug and remove old gas for new.
check links below for why mowers do not start.
Top 5 Mower Troubleshooting Tips Briggs Stratton
When Lawn Mowers Won Start
Mar 21, 2016 | Garden
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Ive replaced my transmission on my walk behind lawn mower it was almost upside down for 2 days ive replaced the gas and oil but it wont start
The gas and oil weren't in the mower when it was upside down were they?
If that's not the issue, then the problem could lie in the fact that neither tank was fully drained before being put upside down. What happens is that the oil and fuel mix and will drain into the wrong area.
My best suggestion would be to leave the mower upright for a few days before trying to start it If need be, drain the oil and gas and let both tanks dry out completely before refilling.
Clean the spark plug and change the filter.
If none of these ideas work, then you will need to take your mower in to be serviced.
Aug 13, 2011 | Troy Bilt 5.5hp Self Propelled Mower
3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED LONG TIME. WOULD NOT START-CLEANED FUEL SYSTEM -GOT FRESH GAS. LAWN MOWER STARTED-HAS A HIGH IDLE NOW AND WILL NOW IDLE AT NORMAL IDEL SPEED. HOW TO...
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Oct 02, 2010 | Craftsman Garden
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
Mar 21, 2010 | Garden
I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 26, 2009 | Garden
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
