Question about LG DU-37LZ30 37 in. LCD HDTV
My tv is a LG 37 LC2DB with Freeview
My tv works very good, picture excelent and every thing very easy to use, but I have a problem: I have connected a VCR Sony through a Scart to the AV1 a JVC Divx DVD through a Scart to the AV2 and a Sony DVD recorder throug another Scart to the DTV OUT to be able to record straight from the freeview. The problem is: I cannot record from freeview through the DTV OUT. Actually the only thing I can do with the Sony DVD recorder is swithcing it on, I put a dvd and I cannot watch it because I don't know how to, I cannot record with it, how can I record freeview? How should I connect the DVD to record from the freewiew? How can I watch films throug this DVD? Thanks in advanced for your help.
charcois
  • 763 Answers
SOURCE: TV CONNECTIONS
if your cables are not compatible or incorrect ends then try to buy an adaptor to fit to the right connectors. so you will be able to connect each ends.
CHARCOIS
Posted on Sep 16, 2008
SOURCE: how to record freeview programs off tv with built in freeview
I have recently purchased a TV with built in Freeview. How can record programs onto my VCR? How many scart cables do I need?
Posted on Nov 11, 2008
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
I have a Sharp Aquos 26-D44E. The factory preset PIN on this one is 1234.
Posted on Feb 10, 2009
SOURCE: Can't tune my sony KD-28DX50-U TV into freeview channels
Phone SONY UK digital helpline on 08706 001717 and they will give you the phone number of your nearest authorised SONY dealer to come out and fix the problem free of charge.
Posted on Feb 17, 2009
  • 458 Answers
SOURCE: Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
Posted on May 27, 2009
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
Picture on freeview appears to be in slow motion
Hello.
Connect DVD player to your TV and make sure that there is no "slow motion" while using it. If everything seems to be OK - problem has nothing to do with TV. It is outside of it and could have something to do with your signal source (like cable box, etc).
If DVD have same issue - main board in your TV have to be replaced.
Regards.
Russ.
Dec 01, 2010 | LG 37LC7D 37 in. LCD HDTV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Lg 37 lc2db cuts off after 2 minutes
Replace swollen capacitors on the power board.
Nov 01, 2009 | LG 42LC2D 42 in. LCD HDTV
WHEN I TURN ON THE TV ITS MAKES A VERY LOUD CRACKLING NOISE.
If you have lost your freeview channels & your picture has been breaking up (pixelating / freezing) etc as well as crackle on the audio, then I would suspect you check your antenna, it could be your incoming signal is weak which would give you these problems.
Aug 13, 2009 | LG 37LH55 37 in. LCD TV
Hi I have purchased a Panasonic TX 37 LZD80. It is 1080p and has a built in freeview. The tv came with the usual factory settings but the image quality looks dire - it was a considered purchase after much...
Hi, the best thing to do is do a factory reset check your manual for details on doing this. if this does not work i would advise taking the set back to where you got it and they should replace the set for you
Mar 11, 2009 | Panasonic TX37LZD80 37 in. LCD TV TV/HD...
Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Nov 11, 2007 | Panasonic TH37PX60 37 in. Plasma...
Rolling picture
Try the free view and see if the box is bad, then if it still does the sane thing, I bet theres a bad connection on the driver IC board, on a connecting ribbon cable, or a bad drive ic. These are things that a user should not attempt to repai, as there are no user replaceable parts inside this set and should be serviced by a train tech. Good Luck
Oct 10, 2006 | LG 37LP1D 37 in. LCD Television
LG DU-37LZ30 37 in. LCD HDTV Logo
69 people viewed this question
Computer Repairing
Computer Repairing
