Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool LSN1000kq (direct drive) will not spin.
It aggitates and drains fine. It will start to spin if you manually spin it. Is this a timer issue or a transmission problem?
  • Anonymous Feb 28, 2009
    I have the same problem you mentioned above. I just paid an appliance repair guy to come out and inspect it. He looked underneath it and said the transmission is leaking oil on the clutch (or the clutch is leaking oil on the transmission). He said to replace them it would cost more than I paid for my 7-year-old washer.
  • 163 Answers
Hi!!! you seem to have a trasmission problem..to expensive too repair unless you have a warranty for it..good luck..
Posted on Jan 04, 2009
Whirlpool Washer will not drain and spin
how long have you had it? it is possible that your pump might be clogged with debris. Just need to clean it out.
Aug 11, 2012 | Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Whirlpool LSR8444 washer, timer works but no spin or aggitation
Your problem is a broken drive coupling between the motor and transmission. Replace the drive coupling.
Jul 27, 2009 | Washing Machines
Washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Apr 30, 2009 | Amana NTW5100TQ Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
216 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
