Question about Hotpoint Washing Machines
Error f05 HiI have a hotpoint bs1400, and when its just about to go on spin the error code F05 appears, apparently meaning pressure switch jammed on full, can you help?thankspaul
  • Anonymous Mar 19, 2014
    error code F05
  • Anonymous Mar 28, 2014
    Hotpoint aquarius washing machine when goes to spin get error code F 05
  • Hotpoint Master
  • 3,463 Answers
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
It flashing f05
Error F05 on some Hotpoint washing machines means the pressure switch has "jammed" on, so the machine thinks it's full of water and refuses to spin.
http://howtomendit.com/answers.php?id=53666
Aug 04, 2015 | Washing Machines
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Error code f05 flashing, what is this and how serious?
Error F05 means the pressure switch is jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Does not spin fault code F-05
Error F05 means that the pressure switch has jammed on full.
Do the following.
Remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose on to pump, and check for blockage or obstruction here as well.
Hope this helps with your problem.
Dec 25, 2009 | Hotpoint Washing Machines
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Washing flashig error code f05
hope this helps....
Oct 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
206 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
