Toshiba indoor unit front cover removal
Toshiba RAS 10 m nkpx
  • 5 Answers
SOURCE: Hitachi ras-5h gse
first: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Posted on Jan 26, 2009
  • 400 Answers
SOURCE: Hitachi RAS-25CHA will not work after power supply -brown outage.
Is the unit responding to remote instruction at all? It does sound like your board is gone. This is usually a capacitor (blue or green and round flat disc) on the pc board, and possibly one of the diodes (small black cylindrical shape with a white line on one side) Often it is the compressor drive relay (rectangular black box) on pc board. If however you have managed to find a replacement board. The plastic heads holding the pc board are released by using a small long nose pliers and pinching the bit sticking through the board. The rest is simply a matter of changing one wire at a time from old board to new board. Or a good method is just to take a snapshot with a camera to refer to regarding the wire positions.
Posted on Mar 05, 2009
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
  • 10 Answers
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Posted on Jul 15, 2010
hvac1960
  • 2133 Answers
SOURCE: Toshiba Heat Pump / Air
Normally maximum indoor unit carries sealed motor. Hence, replace bearings.
Posted on Dec 04, 2010
Testimonial: "Thank You. If this is the case then its not an easy task and I'm surprised that its not made to last more than only a couple of years..."
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
I have a "Hitachi split type air conditioner model RAS- 3098U", and its started leaking today from the right side. I didn't install it and I can't figure out how to remove the front cover to l
water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
Aug 13, 2012 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
grille is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Jan 30, 2009 | Heating & Cooling
Heya,
I am an ex warrenty agent for Hitachi in Western Australia and I will be able to take you through some tests if you want. But from the sounds of it I think that you will be up for a new indoor PCB as these are the most common things to go when there are power failures. If you would like me to go through it with you let me know. But first where abouts are you in Australia?
Jan 08, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi ras-5h gse
Sep 05, 2008 | Hitachi RAS-09UH Air Conditioner
Outside unit has frozen
Check your air filter and evaporator at the indoor, and also the outdoor condenser coil if clean, be sure that the outdoor has no obstruction to both front and back of the unit. If dirty then clean both indoor and outdoor. If clean let the ice melt by turning of the unit and unplug the power cord or off the circuit breaker to reset the error if error is present. And on the unit again and observe if icing is present when unit is operating. If icing is present after 10 to 30 min of operation then the unit is under charge.And while unit is operating adjust your thermostat to higher temp. to check if thermostat is operating normally. If the outdoor will trip off after the adjusting the temp. then your thermostat control is ok if not then the thermostat control have a problem.
Jan 21, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
