Question about Troy-Bilt Garden
Idles but won"t stay running
  • Jerome Mannion Oct 05, 2013
    no the engine is running fine its the head that stops like the clutch is gone
  • 430 Answers
Does it die or bogg down when you accelerate the motor? That is a symptom of a lean condition. Check your fuel filter, fuel lines ( if the filter has come off the end of the fuel line and is laying loose in the tank then the fuel lines need to be replaced, also replace if the fuel lines are stiff or discolored ((brown)), or the carb needs to be adjusted or rebuilt.
Posted on Nov 05, 2012
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
Won`t stay idled
Can you describe the problem ? Have you checked the idle air control valve ? Is the throttle body clean ?
Jul 03, 2013 | 1985 Pontiac Fiero
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Aug 15, 2017 | 1998 Ford Expedition
Pw50 fires but won't stay running
Hi, Jj9871 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
pw50 won start please help
My Son Has Yamaha Pw50 That Will Start But Won Stay Runn
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50 Owner Manual
Apr 14, 2012 | 2004 Yamaha PW 50
1996 sportsman 400 wont idle. Had the carb cleaned by a "mechanic" after the bike took off wide open and driver was injured. He said the float stuck and he "fixed" the problem. Now...
I have NEVER heard of a float sticking and causing that issue. Sounds to me like the Electronic Throttle Control (ETC) on the right handlebar isn't or wasn't adjusted. There is a thumb nut on the throttle cable coming out of the ETC switch. Loosen the screw and turn the cable in or out to get 1/16 to 1/8 inch freeplay on the thumb throttle. Too loose and it won't idle, too tight and it will pull the throttle cable tight and rev engine. It could also be a carburetor issue if it runs with choke. Either the idle screw isn't adjusted or the pilot jet is plugged. There is a large thumb screw coming off the carburetor, turning clockwise will turn the idle up. Let me know if you need anything else, Daniel.
Sep 18, 2011 | Polaris ATV
Moped won't stay running on low throttle, it will
Your IDLING JET IS CLOGGED or the settings on the SLOW speed on the idling screw is not correct. Sometimes dirt can cause issues and so it might need an overhauling of the carburater.
Jul 28, 2011 | 2007 Generic XOR 50
Won`t stay running after it warms up not overheating
is it carb, or efi ? and what size engin?
May 30, 2009 | 1985 Ford F 250
Garden Logo
2,067 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
