Question about Toshiba Regza 52XF550U 52 in. LCD HDTV
Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
TV has exhibited absolutely no problems previously, all audio and video has worked like new. Satellite channels (DirecTV) all work fine, local channels are received on an antenna. A couple of days ago one of about 15 local channels became unusably garbled, all others work as normal.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
Posted on Nov 05, 2012
mistersony
  • 320 Answers
SOURCE: No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Posted on Nov 11, 2008
  • 8457 Answers
SOURCE: No sound on certain channels.
All the apartments complex have it than it not ur tv.It the cable company signal problem.Tell the maneger call talk to the company check the wiring.
Posted on Jan 13, 2010
  • 50 Answers
SOURCE: Toshiba 42hp66 without an image
Hello, You most likely have a bad Y sustain board! Part #'s are:
6871QYH053A, 6871QYH053B, 6870QYH005B, 6871QYH953A, 6870QYH105B.
Here is a link to the part you need!
http://www.discount-merchant.com/Y-SUSTAIN-PN-6871QYH053A-6871QYH053B-6870QYH005B-p/vizio-sku9506.htm
I hope this help you! Please feel free to give me a call or message me if you have any questions! Ask for Dave!
Thank you! :-)
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Posted on Aug 26, 2009
SOURCE: How do we make my TV capable of receiving regular
You would have to hook up an external TV antenna on the UHF/VHF band and run a coaxial cable from the antenna to the TV and plug in the "Belling-Lee" connector into the "Antenna" socket at rear of unit.. This should enable reception via "Normal TV"
Posted on Jan 24, 2010
SOURCE: hi, i resently bought a toshiba regza 42
I have the same problem. You need a new audio/video board.
Here is how mine sounds:
http://www.youtube.com/watch?v=yAXqWIhQYa4
Posted on Apr 30, 2010
Why is there no sound on one channel?
This could be a problem at the transmitting end.
Mar 14, 2016 | Televison & Video
We get garbled sound on new sharp aquos +Q TV 60 inch
If you are using an antenna for input, then you are probably partially losing sync with the signal. You may want to adjust the antenna or try a signal booster. If you have input from a cable box, check the HDMI cable, possibly replacing it with a new one. If you're using a cable box with RCA cables, (Composite or component inputs) then the problem is most likely with the cable box loosing sync with the channel feed.
Jan 29, 2015 | Sharp Televison & Video
Sound is garbled on one channel only-using antenna.
Try using a different antenna or moving the antenna to a different ocation. if none of that works you might have a bad signal board. You can get parts at www.interliquidparts.com
Dec 12, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
We can't get any channels to tune in with the over the air antenna.
I solved this problem by purchasing an external indoor HD TV antenna. Once I plugged it into the TV, I received approx 20 channels, picture and sound are fine. The antenna that comes with the TV appears to work only when you are located quite close to the source of the TV signals.
Nov 28, 2010 | Sharper Image TSILCD7PTSD TV
This tv is not connected to cable or dish, but has an interior antenna. up to about 2 months ago, we could get network channels (abc, nbc,cbs) which is all we wanted. Suddenly CBS dropped out, says "no...
How far away is the CBS station? Are there any obstacles that would block the signal (say new construction)?
What channels do antennaweb.org or tvfool.com suggest you will get from your location? (Antennaweb is more conservative and assumes an outdoor antenna.) Do you need to rotate your antenna to get one transmitter or the other? Indoor antennas are more likely to get interference and direction issues.
You may want to restore your TV to the default and then rescan the channels. (This may or may not help. It usually helps more with scrambled information than lost channels.)
I hope this helps.
(good luck. I've had issues with my CBS and Fox affiliates (sharing a transmitter location). At first it was clearly my TV and the reset helped. Now I have no clue as to the cause - the external TV antenna gives a strong signal on the other TV. The problem TV says the signal is bad and this is the closest transmitter and antennaweb says I should get it easily. Even pointing the antenna straight at the transmitter doesn't help.)
Jun 10, 2010 | Element Electronics FLX1511B 15 in. LCD TV
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Samsung LCD LNT4042H
Hi Barb,
Unfortunatly the problem you are asking about is a normal happening in our area with customers of mine that use rabbit ear or house mounted antennas ( Normally not cable or satellite dish). This problem sounds to me like a lack of signal strength on certain channels where your loosing your sound. Since your LCD TV is digital it requires a bit more signal strength to produce sound and picture. Maybe a better antenna, or redirection the antenna toward the station transmitter. Hope this helps.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba Regza 52XF550U 52 in. LCD HDTV Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
