When i try to sew machine goes uh uh uh. I have to keep pushing foot like the gas pedsl in the car after doing this umpteen times it will eventually start, but if i leave the machine fo awhile i have to go through the routine all over again
There could be something wrong with the motor or the power
cord or even the foot pedal, or the machine could have a internal
parts problem,, it would be a good idea to have the
machine check to see what is wrong.
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
SOURCE: start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
SOURCE: I can't find a 1/4 inch foot fo rmy sewing machine anywhere...
I've been looking for one as well...this store seems to have it although I have not yet ordered it:
http://www.raichert.com/azsewingstore/p-JTLF15.htm
