Question about Omron HR100C Heart Rate Monitor
My hr100c wont stop beeping. how can I stop the double beep every 2-4 seconds?
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Cobra 29ltd bluetooth,bluetooth stuck
To disable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a double-beep. You
may hear 1 or 2 single beeps, just keep holding the button until you hear a double-beep. The
Bluetooth light on the CB should remain dark.
To re-enable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a single beep. The
Bluetooth light on the CB should blink every 10 seconds.
Sep 25, 2011 | Cobra 29 LTD CB Radio
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
My PS3 wont read PS3 games
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 02, 2011 | Sony Playstation 3 (PS3) Console
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Nov 07, 2008 | Acer NSK8458AN Keyboard
My maytag m6x06f2a-f window AC wont stop beeping
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Jun 07, 2008 | Maytag M6X06F2A Air Conditioner
Omron HR100C Heart Rate Monitor Logo
49 people viewed this question
Top Omron Exercise & Fitness Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
JonSnell Electronic
JonSnell Electronic
Are you an Omron Exercise and Fitnes Expert? Answer questions, earn points and help others
