Question about Master Bilt 25.5 cu. ft. Freezer GT80
Compressor cycles on and off continuosly - Master Bilt 25.5 cu. ft. Freezer GT80
    Top Expert:
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 10, 2012
Compressor cycling
chattering relay can cause compressor to over heat. replace that first and see if that does not resolve your issue.
Jun 06, 2013 | Hoshizaki Freezers
Freezer compressor
How is temperature controlled, refrigerant pressure? Thermostat? Does the top of the compressor get too hot to touch?
Aug 24, 2017 | Freezers
Short cycle in freeze mode
a short cycle usually means it is cutting out on high or low pressure.If its low pressure add gas.If its high pressure make sure condenser coils are clean.amp check compressor if its real low its low pressure if its real high either high pressure or bad cap or bad compressor windings.
Apr 18, 2012 | Freezers
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Freezer runs continuosly, temp on control reading -8 degrees,unit never shuts off. also get alot of condensation on doors seems door heaters are not working.
Lets start with why it wont shut off. This seems most likey the thermostat. Turn down the t'stat to 1. if it doesnt shut the compressor off then recommend to replace t'stat. If you do defrost the whole freezer so that when you turn it back on it should take care of the condensation on doors
hope this was helpful
Mar 12, 2010 | Freezers
My true double door freezer will not go below 27 degrees. a technician checked the refrigerant and it is ok , the compressor runs, the equipment is clean, the thermostat is set as cold as possible, but it...
Some thing does not add up.
Things to check:
Is the compressor pumping properly?
Get a second opinion on the freon level.
Is there something effecting air flow in the conditioned space?
Are there regular defrost cycles and is the evap completely cleared at the end of the cycle?
I would start here.
Let me know and we can go atillte farther.
Oct 20, 2009 | Freezers
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Will not kick on
Hi, did the whole refrigerator shut down or just the compressor?
If the compressor only shut down, the compressor is bad.
If the whole thing shut down, it might have went into defrost cycle.
Does this help?
Vic
May 30, 2009 | Freezers
Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Mar 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Master Bilt 25.5 cu. ft. Freezer GT80 Logo
53 people viewed this question
Top Master Bilt Freezers Experts
Dennis Boxerman
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you a Master Bilt Freezer Expert? Answer questions, earn points and help others
