Question about Kirby Vacuums
How to install the belt ajuster on Kirby Ultimate G
I dismantle the belt ajuster assembly on my kirby vacuum and i am having a hard time putting it back .
  • Kirby Master
  • 18,394 Answers
Watch this video
Posted on Nov 05, 2012
ttech
  • 139 Answers
SOURCE: kirby 2hd
On the Front of sweeper is a Tab Turn it and it will release the Beater Bar assembely Put the Belt around the Bar and put the Belt on the inner tab Turn and the Belt should go around motor Good luck ttech
Posted on Jul 24, 2007
b0sslady2001
  • 357 Answers
SOURCE: kirby shampoo instructions how to assemble shampooer
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
This is also a great place to order Kirby supplies!
Posted on Jun 22, 2008
Arius
  • 446 Answers
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
b0sslady2001
  • 357 Answers
SOURCE: It's been awhile since I have used my shampoo
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
Marci
Posted on Jun 28, 2009
  • 10 Answers
SOURCE: How to put a Kirby Vacuum belt back on
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Posted on Jan 27, 2010
My belt broke on my kirby G-5. I havent put a belt on it in 10 years. I having problems getting it on.Can u tell me the right way? Thank you.
Greetings,
I recorded a video repair of replacing the belt for the Kirby generation vacuum cleaner. The following video will walk you through step by step on how to replace your Kirby belt, as well as doing some basic maintenance to the roller brush to prolong the life of your belt as long as possible.
How to Replace the belt on a Kirby Ultimate G Vacuum Cleaner;
I hope that this video was helpful to you in repairing your Kirby. If you found the video to be helpful, please kindly rate the video helpful by clicking on the Thumbs Up Icon below.
Thanks for watching!
Chris J.
Nov 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby shampooer not sucking water up
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How to change a band on a kirby vacuum?
I think you mean belt??
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby
Take the nozzle of, remove the brush roll, put the new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jun 29, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum
Jun 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Installing belt on G7D Kirby vacum
For belt replacement instructions watch video
http://www.goodvac.com/
Good Luck,
Rocky
May 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do i put a belt on my kirby vaccum
here is a link to a site with step by step instructions for replacing a belt on any G series kirby...it also works for the new model.
Hope this helps! :)
Feb 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
If this is a Hoover vacuum, which model is it?
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
