Question about Whirlpool Washing Machines
THE CAP TO THE FILTER IN THE WHIRLPOOL WFS1071AW FRONT LOAD WASHING MACHINE WONT OPEN.
I am trying to clean the filter becuase it keeps telling me to. But when i start to screw open the lid to the filter (round, black & plastic), it wont come off. We tried to unscrew the screws, but the black fliter thing is too fat to fit through the hole to pull out - we can only push it in. I am not sure how to clean the filter if the lid wont open! (i have followed the instructions on the manual too!). Please help! I dont want to call a technician - they are so expensive!
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Could you double check that model number for me?
Posted on Nov 05, 2012
3 Suggested Answers
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
SOURCE: Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Posted on Feb 23, 2010
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
How do I clean the pump on a Whirlpool 6th sense frontloader
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
Sep 19, 2014 | Washing Machines
Hi my washing machine starts but afta 5-10 minutes it keeps tellin me to clean pump... how do i do that and where is the pump?
Try cleaning the filter first. The filter is behind a flap on the lower part of the front panel of the machine. The flap is normally opened by pushing at one side - then unscrew the cap that is behind the flap and withdraw the filter. Clean it thoroughly and replace.
If this does not work you will need to remove and clean the pump itself, which is accessed from beneath the machine, but this is a more major job.
Jan 04, 2011 | Whirlpool AWZ412 Front Load Washer
Clean pump light keeps coming on the machine is a WHIRLPOOL WFS1071AW 7.5KG
Possible thaat the drain pump is clogged and must be cleaned out as the filter is choked.
so remove the drain and have it cleaned and reset , also check you inlets and drain hose.
Sep 30, 2010 | Washing Machines
Washing machine will not spin. have cleaned out
I have problem with my washing machine.could you help me please.
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump red light on Whirlpool WFS1071AW, How do I?
TAKE OUT THE SCREWS ON THE BOTTOM PANEL AND ON THE INSIDE OF THE MACHINE NEXT TO THE PUMP YOU WILL FIND A PIECE OF PLASTIC WITH A SMALL HANDLE, ROUND IN SHAPE, PULL THIS OUT AND CLEAN THE FILTER
Aug 11, 2009 | Whirlpool Washing Machines
Vibrations in Whirlpool WFS1071AW
Hi the problem with your machine is the fact the transit straps have not been removed!! Remove them and you will not hear another thing from it. Look at the manual to find out how to take them off!
Dec 28, 2008 | Whirlpool AWM5125/1 Front Load Washer
Our simpson 100 enviro won't drain. We think we need to clean the filter, but we can't remove the filter from the machine. How can we do this?
front loader filters are at the bottom use a screwdriver to remove it may be stuck full of coins.also make sure you dont have a button pressed in by mistake.hope this helps you
Mar 09, 2008 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
