I have a whirlpool cabrio model # wtw6600sw2 top load washer that gets stuck at 24 mins (the rise and spin) or at 12 mins (the drain and spin). This doesn't happen every time, but it happens a lot
  • Tim Twichell Nov 05, 2012
    I never get any error codes either. It just gets stuck.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Here is the service manual for that unit. Run it thru the diagnostic mode to see if you get any error codes to pop up.
Posted on Nov 05, 2012
blueextc3221
  • 15935 Answers
SOURCE: My top-loading Inglis Liberator washer doesn't spin
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
  • 9 Answers
SOURCE: washer machine drains while filling
If the pump is actually coming on at all times, then I imagine this machine has a completely electronic control system ? - i.e. No mechanical timer ? - If this is the case, then the switch that controls the pump is an electronic solid-state device, or, more rarely, a relay on the board. Looks like you'll need a new power board.
Posted on Sep 16, 2007
  • 1937 Answers
SOURCE: my whirlpool cabrio washer has ld code. have
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
Posted on Oct 20, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Whirlpool Cabrio wtw6600sw2 top load washer is dumping water
Could you please describe the problem you are having a little better?
Dec 01, 2012 | Whirlpool WTW6600SW Top Load
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have change stuck is washer making noise when washing. How do I get it out
If this is a Whirlpool Cabrio, it has two pumps. One is the drain pump and the other is a recirc pump. In most cases, loose change an other items end up in one of these pumps. The following link explains how to access and check the pump(s) on the washer for obstructions.
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
If you have something stuck in the wash tub, you will need to remove the washplate in the center of the wash tub. Follow these steps:
1. Lift the washer top panel by locating the retaining clips in the seam along the front (about two inches in from each side). Use a putty knife to push in while lifting on the top panel to release.
NOTE: Its a good idea to tape the lid shut to prevent it from flying open when you lift the washer top.
2. Remove the wash tub ring. This is the plastic ring around the perimeter of the top of the wash tub. There are a series of release tabs around the tub that you can pry with a screwdriver.
NOTE: The washplate will not come out with the tub ring in place.
3. With the tub ring removed, pop the center post cap off the washplate. Locate the center nut and remove. Hold the washplate with one hand as you loosen to keep it from turning.
4. Lift the washplate out of the tub.
With the wash plate removed, you should easily be able to access anything stuck in the spin basket.
If you have any questions, or if this is NOT a Cabrio, please post back and let me know. I hope this helps you.
Mar 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It's stuck on drain/spin the water won't empty and the time stays at 13 min
Unplug unit for 30 min, then plug back in.. Doing this will reboot the control board
Jan 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
At high speed spin cycle sounds like a jet engine...
if your thinking bearing, its part of tub assm not basket hub. $200 part
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
619 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
