Question about Dell OptiPlex Motherboard Vid Snd LAN PCIe GX280 D7726
Get a error code 132 on start up, does not boot up
  • Don Johnson Nov 06, 2012
    By chance I found the Dell support site that listed the beep codes and diagnostic lights codes. Beep code 132 means (Memory not being properly identified or used), I then found the Diagnostic light codes of A and B in yellow and C and D green meaning (memory modules are detected but a memory failure has occurred).I removed the two memory modules and reinstalled them, apparently one of them was not seated all the way and the computer booted up right away and seems to be running fine now. Don Johnson
  • Dell Master
  • 5,660 Answers
You are the MAN, Don!
I also think you should remove all Ram Memory modules, and use a pencil eraser to clean the gold plated contact pins.
Why?
Because you obviously have 'corrosion' on those contact pins.
Average example of a DIMM ram memory module, as used in a desktop computer,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
Handle the ram memory module by the BODY.
The Body is coated with a see-through protective plastic.
The Body is everywhere on the ram memory module, EXCEPT the gold plated contact pins at the bottom.
If you are using an eraser on the end of a pencil, and not solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub the eraser up, and down on EACH contact pin. BOTH sides.
Doesn't take much rubbing, or much pressure.
In fact when you are done, you may feel you have done nothing at all.
The gold plated contact pins may Not be bright, and shiny when finished.
I assure you Don, that you have cleaned them. Doesn't take much 'corrosion' to make a bad contact surface.
(Gold isn't supposed to corrode)
Use air to remove the eraser dust. If you have a can of compressed air for computers available, use it. If not air pressure from your mouth will be sufficient.
(Also use compressed air on the ram memory slots)
[Power removed before starting!
Anti-Static Precautions FOLLOWED ]
Regards,
joecoolvette
Posted on Nov 07, 2012
Canon ixus 132 HD gives error e 32. how do i repare it?
Error codes in the 30 range usually point to a shutter problem. Looks like a repair job
Mar 02, 2015 | Canon IXUS 132 16 Megapixel Compact Camera...
Error code troubleshooting
It's your AVCS/cam shaft issue, bring the dealership since this issue is on Subaru TSB. Possible they replace the ECU/ECM unit.
02-132-12R Technical Service Bulletin Diagnosis and Repair for AVCS-Related DTCs P000A, P000B, P000C, P000D, P0011, P0014, P0021 and P0024
Jul 21, 2014 | 2012 Subaru Impreza 2.0i 4dr Hatchback...
What should I do when the Display says Service call 132:Error
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
May 27, 2014 | OKI C5100n Laser Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Icq error 132
how can I fix the ICQ error 132?
Oct 24, 2011 | ICQ Computers & Internet
Error 132 in my laptop pc and bugs acer 4736ZG
If you're searching for a way to repair a runtime error 132 then i will let you in on a state-of-the-art yet very easy-to-use solution so you can stop worrying and get back to work! This type of error pops up a lot; and in a large number of these cases the problem starts in a specific area in your computer. Help is on the way! and actually in practically no time at all - just moments - you will succeed in doing away with such errors once and for all.
The gist of this is, if it's time for you to repair a runtime error 132 you need to scan and repair your registry. As you would imagine, it's very tricky to handle it alone, therefore, it is a bad idea to go that way. In my experience, the best method for dealing with this is to take advantage of an reginout registry cleaner repair program. Registry repair tools are specifically designed to completely examine and correct a faulty windows registry in just a few minutes.
Aug 18, 2010 | Acer Aspire 5610-4648 Notebook
Error when installing Move data process :-132
try to use another grabbee i think there's something wrong with the connection... that's why it display an error message..
Apr 28, 2009 | Computers & Internet
T40 memory upgrade
One of your memory slots may have gone bad. Try putting one memory card in one slot thaen the other. Let us know.
Sep 25, 2008 | IBM ThinkPad T40 2373 Notebook
Ps3 60gb system
If that does not work throw in a new hd!
May 22, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
