Question about Dell Computers & Internet
After installing a new SATA hard drive the PC doesn't 'see' it
After installing a new SATA drive (as the primary to replace a failed unit), the Dell Inspiron Desktop doesn't see the new drive. I have managed to load Windows successfully onto it bu booting from the Windows CD, but I still have intermittent closedown IRQ failures. I suspect this is something to do with the fact that the original Drive was RAIDed, and the new one isn't. So ..... either how do I set the new one up for RAID, or how do I change the Dell BIOS to say that the new one is not RAID?
Many thanks
  • john vecchione May 11, 2010
    start machine hit f2 or delete to get bios screen up look in bios to change raid settings without seeing hard to tell what you did and what raid config you had
    President:
  • 948 Answers
When rebooting, press F2 or Del to get into the Dell setup (BIOS). Once in there, look around for an integrated RAID controller and see if you can disable it.
This may or may not be related to your "closedown IRQ failures" though. Have you set the new drive to match the data speed of the old drive? Earlier SATA had a 1.5 max transfer rate, later it went to 3.0 rate. If the new drive is looking for data at the faster rate that may cause problems too, and you should be able to configure the new drive with the proper rate using utilities available from the manufacturer of the drive.
Posted on Jan 04, 2009
Dell inspiron 3847
Dell has not published the procedures for installing an additional SATA hard drive, the Inspiron 3847 has a second 3.5" bay, for the second hard drive next to the primary hard drive, there should be a set of rails located in the bay, two 6-32X1/4, phillips head screws are needed, to attach the rails.
The procedures on pages 26 to 28 of the owners manual should give you an idea of what is required for the installation.
http://ftp.dell.com/Manuals/all-products-Infodev/esuprt_desktop/esuprt_inspiron_desktop/inspiron-3847-desktop_Owner%27s%20Manual_en-us.pdf
You will need a SATA data cable there should be a spare SATA power connector inside the case.
After installing the drive enter the system setup and check that the hard drive is 'enabled' [on] and recognized.
For Windows to recognize the second hard drive, it must be partitioned and formatted.
Go to Control Panel, Administrative Tools, Computer Management, Storage, Disk Management, right click new drive, select format, then you can assign a drive letter.
May 08, 2014 | Dell Computers & Internet
2000 0146 code
This is a hardware problem with hard drive. You need a new, 2.5", 9.5 mm SATA notebook hard drive. Replace the failed drive, then install latest drivers
Sep 24, 2013 | Dell Vostro 1014 Laptop Computer (Intel...
Unable to make SATA dive as primary master .
Remove the IDE hard drive, and connect the SATA drive to SATA0 (zero) port. Install the OS on SATA drive. You may have to check BIOS. F2 on boot should get you there.
Oct 09, 2012 | Dell Precision Computers & Internet
SATA Primary hard disk drive failure
Sounds like your hard drive has failed and will need to be replaced. You will need to make sure you have all the recovery cd/dvds Dell sent with the system; or you created when you got the system. The new hard drive will be completely blank, so you will have to install the OS, drivers, and other software from these CD/DVDs.
Hope this helps
Apr 25, 2012 | Dell Dimension XPS 400 PC Desktop
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
I have a dell optiplex and the hard drive has been removed how do i get new hard driveto run tried to install windowsxp disk failed on restart would not find hard drive HELP
Did you replace the old hard drive with a new one?
Check the connections on the drive itself. When you plugged the new one in, there should have been two cables you plugged into it. 1 small one that goes to the motherboard (called the SATA cable), and one wider one which comes right out of the power supply. If either of these is not plugged into the hard drive, you would get a message that says "could not find drive".
Check your connections and try again. If they're ok, then write back with as much detail as you can provide.
Mar 14, 2010 | Dell OptiPlex GX520 PC Desktop
Installed new hard drive and dell will not reconize it as primary drive
make sure that the jumper setting of your harddisk is properly mounted in master and connect the IDE cable to IDE 1 or SATA 1 connector...
Feb 08, 2010 | Dell OptiPlex GX270 PC Desktop
Have a dell optiplex sx280 and its giving me the SAA primary
If your hard drive has failed a) you need a new one, b) you will have to reinstall the Windows system but c) you will have lost anything you stored on the computer. This is why we encourage people to have backup systems.
Dec 01, 2009 | Dell OptiPlex GX280 PC Desktop
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
Alun Cox
