Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 does not recognize dvd
Every time my son installed itunes my dvd would dissapear. I could go in to registry and delete filters and it would work again. This happened 5 times. The last time it wont come back. Running vista. re intalled os from d: , still no luck. Any ideas?
    Scholar:
  • 35 Answers
I have an acer aspire 5100-4720 notebook. The DVD Drive will not appear in my computer. It shows up sometimes and work perfectly well. But most times, it is missing and does not function. I check the...
Go into system and roll back driver. If this doesn't work, go into hardware and remove it. Restart pc. It should try to reinstall. It may ask for driver. Have it ready.
Apr 24, 2011 | Acer Aspire 5100 4720 Notebook
I have an acer aspire 5100-4720 notebook. The DVD drive will not show up in my computer. it does sometimes and work properly, but most times it is not present.\r\nwhat could be the cause
try system restore. or try to delete the upper and lower filters. To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
    Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, if you have UpperFilters, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, if you have LowerFilters, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Apr 24, 2011 | Acer Aspire 5100 Notebook
Hello I have Samsung SH-S223 and it doesn't read any of CDs or DVDs My computer recognize DVD-ROM and everything seems to be good maybe I need drivers for it? But all drivers have a letter after S223....
Do you have itunes installed?
If so Itunes put upper and lower filters in the registry key taking control of the dvd.
Goto Start type in cmd if it is vista, if it is XP click on run, then type in cmd, then regedit goto these keys in registry.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
Goto each key listed above and delete upper and lower filters then close out of registry editor goto device manager go down to dvd/cd rom drives right click on the dvd drive and delete it and if asked to delete drivers for this device check box to delete drivers then close out of device manager and restart the computer.
These upper and lower filters will say something like Gear Aspi.
Nov 14, 2010 | Samsung Computers & Internet
My Acer aspire 4720z DVD drive not working, its not reading any DVD / CD's.. what would be the problem and how can i solve this
Step 1 : Check out You have Apple's itunes or Quicktime player installed in your system.I have seen same problem as your's after installing  Apple's itunes or Quicktime player. But it was solve after uninstalling the softwares.
If you don't have  Apple's itunes or Quicktime player install in your Notebook, Try this
Step 2 : 1) click the start menu
2) click on "run"
3) type "regedit" and click ok
4) go to string key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5) delete "upper filters" and "lower filters in the right side window.
6) right click my computer in the start menu.
7) click properties
8) go to the hardware tab
9) click device manager
10) expand the dvd/cdrom drives
11) right click the dvd rom and click uninstall
12) restart computer
and check if it works now.
Step 3 : BIOS upgrade
Go to this link below
http://support.acer-euro.com/drivers/notebook/as_4720.html
and download the BIOS accroding to your Operating system and check.
Note: I don't recommend the Step 3 as sometimes if BIOS upgrade fails,it might make your Notebook permenently unsuable.
In case you want to try step 3,Consult your manual well before undergoing the Upgradation process.
Jan 04, 2010 | Acer Aspire 5100 Notebook
My Dvd/cd not working
Hey Hi.
FIRSTLY MAKE SURE SINCE HOW LONG YOU ARE HAVING THIS PROBLEM AND TRY SYSTEM RESTORE IF YOU HAVEN'T TRIED IT AND IF YOU HAVE THEN FOLLOW THESE STEPS...
FIRST METHOD SYSTEM RESTORE
WINDOWS XP METHOD
Start > Run > All Programs > Accessories > System Tools > System Restore > Select A Highlighted Date And Then Click on it and then system will restart on its own.
WINDOWS VISTA METHOD
START > SEARCH > SYSTEM RESTORE > > Select A Highlighted Date And Then Click on it and then system will restart on its own.
In process of system restore any type of software installation made between the dates selected and current date would be gone which you can easily install after the issue is fixed if that was not the cause of the issue
1) Click on Start -> Run -> Regedit-> Registry Editor Will Come Up.
2) Then Follow These Registry Settings By Clicking The Small Triangle Mark In Front Of It..
3) HKEY_LOCAL_MACHINE
SYSTEM
Current Control Set
Control
Class
OR SOMETHING WHICH IS SIMILAR TO IT BUT IT SURELY HAS THE E965 IN IT. IT WOULD BE NEARLY 5TH or 6TH Registry Key....
In Short Guide Yourself To This
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
Once You've Reached In The Registry Key Then On The RIGHT HAND SIDE BOX Right Click upper filter and lower filter and then delete it...
THIS LINK WILL HELP YOU IN SEARCHING FOR THE CORRECT REGISTRY KEY VALUE AND DELETION
CLICK HERE FOR THE LINK
Restart Your System
See Everything Would Be At Place...
Reply To The Post If You Need Any Further Help....
May 31, 2009 | Acer Aspire 5100 Notebook
My Acer Asprire 5100-5674 no longer recognizes the cd/dvd drive.
hi, cd drives do wear out or just break, most time it is software related. but they can just stop working.hope this helps. good luck
Feb 26, 2009 | Acer Aspire 5100 Notebook
Unknown cd-dvd rom driver for Acer Aspire 5100
the possible cause could be upper lower filters. does the cd drive show up in "My Computer"?
if so follw these steps -
click start-> run-> type "regedit" (no quotation)-> click file-> export(make sure that all is selected and that save location is in the C: drive, very important.) -> find this reg key - HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
make sure this is 100% right. now left click it once and stuff will come up in the right side of the window pane. delete the entries on the right side that say "upper filters" and "lower filters". restart your pc. hopefully this should work.
FYI, the registry is everything about the pc, be very carefull not to delete the wrong thing
Jan 25, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 21, 2008 | Acer Aspire 5100 Notebook
Dvd
Try doing this: Step 1: Start Registry Editor
loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
if after deleting the upper/lower filter it still doesnt work try to download the driver for the device and install it.
inform me what happens
francis
Jun 04, 2008 | Acer Aspire 5100-5022 Notebook
Dvd drive
go to systems tools and check if it is connected corretly if not sounds like your drive is shot to me linda
Apr 21, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
