I have a kenwood dvr 7000 7 years old, now the problem is optical or coxial digital input is not working. pls let me know which parts is defective. Thank you
SOURCE: JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Posted on Jul 04, 2008
SOURCE: no sound fom optical input
Do you have your TV hooked up, so you can see the AVR-4800 system menu on its screen (if not, see the manual). You need to go down to the digital input menu item where you associate each component with its input source, whether it is coax, optical 1, optical 2, ..., etc.
Posted on Feb 17, 2009
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Posted on Jul 26, 2009
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Kenwood KRF 7775D not working with Digital Inputs
First of all my nick is Rifaa.
Secondly do you still have the amp
Feb 27, 2009 | Kenwood DVT-6200 System
No sound fom optical input
Dec 07, 2008 | Denon AVR-4800 Receiver
How do i use the dolby digital
You have to connect your dvd player to your kenwood receiver by using the digital port.
DVD ------------ Digital out
Receiver ------------- Digital input
Apr 09, 2008 | Kenwood VR-405 Receiver
DVD optical/TOSLINK input no longer working
If it's only the DVD input, and you had tested it systematically, like you'd stated, then the input connector could be loose or defective.
iTritek Solutions
www.itritek.com
Mar 24, 2008 | Panasonic SA-XR45S 5.1 Channels Receiver
Receiver compatible with tv
yes digital suround sound is optical spdif k like coxial digital if it dont have analog outs or does it have headphone jack in front run a eth in mini jack to rca offf that to video 1 of sterio ok
Feb 10, 2008 | Televison & Video
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
41 people viewed this question
 Grubhead
Grubhead
