Question about Jl Audio 500/1 Car Audio Amplifier
Power but no sound
Power light comes on and all, no protection lights come on. Its seems to have some burnt circuit board under the Q center and boost knobs. What should I look to replace and are there and diagnostics i can preform to ensure I'me replaceing the right parts?
    Master:
  • 689 Answers
If you want to repair it ,Take it to some one that no what in the hell there doing,
Posted on Nov 07, 2012
3 Suggested Answers
  • 108 Answers
SOURCE: my jl Auido 250/1 amp
You may have a bad output on the amplifier. I would recommend taking it to a local electronics repair to have fixed, or visit a local stereo shop - preferably a JL Audio dealer. Visit their website at www.jlaudio.com to find a dealer near you. You can have your amplifier sent in to JL Audio for repair by an authorized dealer and you'll get a warranty on the repair work.
Posted on Sep 28, 2008
Icehockey35
  • 16 Answers
SOURCE: i have a 250\1 JL amp and it stopped putting out
ground, false power supply!
Posted on Jul 02, 2009
My LG TV is not coming on and is making a clicking sound
These newer type Smart TVs have a small round (disc) capacitor that protects the main circuit board from thermal overload. IF the stand-by light comes 'on' and the TV screen won't illuminate, then that's the issue. If the TV stand-by light doesn't come 'on' at all, check the power fuse. It will be near the power supply input into the circuit board... glass or sometimes ceramic cylinder shaped. Radio Shack has them... bring the old one with you as the fine numbers are hard to read. If it's the capacitor, you'll need to locate it on the main circuit board and unsolder it and then get a new one to replace it. The part is less than $3 and the soldering pencil kit with electronics solder is under $15. A schematic will make finding the thermal protection capacitor easy.
Aug 19, 2017 | LG Televison & Video
My Pheonix Gold Octane 8.O.1 turns on but no sound comes from it
The amp is done and it is going to need servicing. Most likely the magnetron has burnt out
Apr 26, 2010 | Car Audio & Video
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Sony bravia kdl-42v4100 no picture no sound if i disconnect cable running from controller board to main tuner board i get sound but no picture and if i plug it back in you see a picture for a second then...
Sounds like there is a short on the power board or the power board has gone faulty.
Look on the power board to see if any of the capacitors are bulged or if there are any other components burnt out. The TV is going into protect mode because of an over current, which points to a short on the board or a component has gone short circuit.
Thanks
Sep 30, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
TV makes a ticking sound, red light comes on but no picture or sound?
The TV is on protect mode. The Ticking sound is the protection switc that keeps shutting down the TV to prevent more damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 30, 2009 | SharpVision XV-Z9000U Multimedia Projector
Wont turn on hear a faint click sound
The faint click sound is the protection circuit that keeps turning off the TV. This happens when an internal fault is detected. Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected. If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition. The flashing light indicates a diagnostic state called protection. When the TV goes on protection there are only two possible reasons. 1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit. 2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light. If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes. If you are in situation 2 , then there is an internal fault. Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board. Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable. If under warranty contact the manufacturer ringing the number on the user manual If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 05, 2009 | RCA P52812BL 52" Rear Projection...
42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
When the TV goes on protection there are only two possible causes.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
May 04, 2009 | Vizio L32 32 in. LCD HDTV
A repair question for the RCA M50WH74S
connected.
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV picture wont come on, led light blinking, we have sound
Jun 30, 2008 | Toshiba 36HF73 36" TV
Clicking sound!
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Apr 11, 2008 | RCA P60921 60" Rear Projection Television
Jl Audio 500/1 Car Audio Amplifier Logo
42 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
