Vizio gv42l hdtv will not cut on - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. vizio gv42l hdtv will not cut on - 11_5_2012_7_44_23_pm.jpg
Posted on Nov 05, 2012
SOURCE: I have a Vizio GV42L
parental control issue
every one for got the code
how do we reset the code
Posted on Apr 26, 2008
  • 4 Answers
SOURCE: Vizio GV42L 42 in. LCD
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
camckay7626@yahoo.com
Posted on Sep 06, 2008
freetek
  • 5568 Answers
SOURCE: GV42L Vizio HDTV Problem
You didn't mention whether you have any audio; details like that can influence the response.
If you have audio but no visible video, look at the screen from an angle for 10-20 seconds to see if any video is present. If you do see some shifting shadows on the screen and have audio, the backlight or its power supply (inverter) has probably failed.
Posted on Nov 19, 2008
  • 34 Answers
SOURCE: vizo GV42L HDTV Only a blue screen when I turn
look for "blue filter" in your setup and turn it off
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Posted on Aug 10, 2009
GV42L vizio tuner
Your vizio has an internal digital tuner. When you are on air, make sure that it is set up for digital. It might say DTV. Some sets have an analog only and digital only program option in the user menu, or as a seperate input. When in doubt, check your user manual.
May 02, 2012 | Vizio GV42L 42 in. LCD Television
WE BOUGHT A VIZIO GV42L HDTV IN FEB.2007 AND IT JUST RECENTLY WONT TURN ON.THE "VIZIO" LIGHT IN FRONT OF THE TV TURNS ON BUT NOTHING ELSE.
The power supply may have failed, or it is in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board, you can try disconnecting the power cables to the backlight inverter board to see if you can get the TV to come on with sound but will not have picture.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Vizio GV42L 42 in. LCD Television
How do you switch to cable without remote
On the Unit itself, are Buttons, up to seven, 7, of them, usually, ON/OFF, MENU, Channel Up, Down, Volume Up, Down, SELECT/ENTER, Nearly ALL functions available on the remote can be performed via the buttons on the TV. Simply choose menu, and Step through with the Channel & Volume keys, and "Selecting" with the select/enter key. www.scribd.com/doc/.../VIZIO-GV42L-HDTV-Service-Manual
static.compusa.com/pdf/GV42L_HDTV_User_Manual.pdf - United States
Above are your User manual, above that is a service manual.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Hi my vizio tv keeps cutting off.. when i unplug and re plug in it keeps lighting up and shutting off.. What can be the problem its only 2 years old
Theres a sustain problem happening in the power supply unit and it needs servicing. This is very common in Vizio tv's......
Nov 03, 2009 | Vizio GV42L 42 in. LCD Television
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Vizo GV42L HDTV Only a blue screen when I turn
Jun 26, 2009 | Vizio GV42L 42 in. LCD Television
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Mar 13, 2009 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
