I have a Dynaglow Workhorse Model RMCKFA170WH forced air space heater. It will not stay running - shuts down and smokes after 5-10 seconds
When filter is removed, tends to run longer, but I can't run it that way safely.
Buffalo12980
  • 625 Answers
SOURCE: RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Posted on Dec 06, 2007
SOURCE: readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Posted on Jan 23, 2008
tinytrees
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
My heater keeps shutting down. Just put fuel in. Lights and runs about 5 seconds
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 12, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Shuts down after about 30 seconds, blowing some smoke.
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Mar 09, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater 70,000 with factory thermostat will run a few
Set the pump pressure. If correct check the nozzle. Desa recommends annual replacement.
A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics.
Dec 12, 2008 | All-Pro Forced Air Kerosene Space Heater...
Readyheater portable forced air 170,000btu/hr
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
