Question about LG 37lh260h 37" 1080p 1920 X 1080 20000:1 Lcd Tv
Service menu lg 37lh260h
I need the service menu to activate picture settings and disable hotel mode
    Top Expert:
  • LG Master
  • 14,553 Answers
Your best and maybe only hope is to call the hotel unit for LG (not part of the main unit) to see if they will help or refuse you.
Posted on Nov 05, 2012
Helllo, wanted to know how to get out of hotel mode
The following are for LG TVs: From your remote, push MENU button for 5 seconds then type 1105 and press OK. You should now have a special menu displayed where you can modify the settings or disable hotel mode. Use the same procedure to go back and modify or enable hotel mode.
Oct 20, 2014 | Televison & Video
How do I turn off Hotel Mode on my Lg 37LH260H T.V
Refer its user manual for details. In most cases, you might have to enter its service mode option to make it normal mode; out of Hotel mode. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 26, 2014 | Televison & Video
Unlock lg hotel tv
To release the hotel mode to normal mode, you have to enter its service mode menu. If you wish to get more details about how to enter, adjust and exit the service mode, check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 18, 2013 | Televison & Video
LG TV 50PQ300:'Keylock on' .Cannot select 'set up' or 'input'.only AV1 works. Can anyone help please???
Press and hold MENU buttons on front panel and remote control until service menu appears.
Press MENU button once again.
Disable HOTEL option.
I hope this helps!
Apr 08, 2011 | Televison & Video
How do i reset this tv?
The TV will search for active channels and add them itself. Use the remote to select the on screen menu and go to the Channel Setup mode. Then just push the up arrow and it will add the channels for you automatically.
There is a possibility that this set has another "mode' where you can select "hotel" or "standard" if it's there make sure you set that to standard the "hotel" mode disables some of the features like the ability to set the channels. I can't find this owners manual on line for free (RCA usually won't provide them) I can't be more specific. I doubt that you got a copy of the owners manual when you got the TV.
Zashiban
May 31, 2010 | RCA F27442 27" TV
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Rgb input is dissabled
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Dec 12, 2008 | LG 32LC5DC 32 in. LCD HDTV
LG 37lh260h 37" 1080p 1920 X 1080 20000:1 Lcd Tv Logo
498 people viewed this question
