Displays on screen unuseable signal.
Tried to hook tv up to our cable box but will not show it
  • 3 Answers
Your cable input signal is leaking just cover it with a rubber and be sure that the earthing screw fittings are properly tightend
Posted on Nov 05, 2012
premtech
  • 934 Answers
SOURCE: YPbPr inputs not working
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Posted on Jun 11, 2007
  • 236 Answers
SOURCE: Have sound and OSD but no picture
You may have a problem with the video switching IC. Stargazer
Posted on Aug 29, 2007
  • 15 Answers
SOURCE: Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
Posted on May 26, 2008
  • 48 Answers
SOURCE: unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Posted on Mar 14, 2009
SOURCE: RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Posted on Jan 12, 2010
I have my rca model f36665 hooked up strait from the wall to the tv and I can't get it to find the channels. do I have to have a cable box?
First if cable I presume you have entered the menu and selected cable.
Another possible reason is the tuner/s in this set are bad---hook a DVD or something to one of the rear inputs and see if set works.
If set works that way and tuner turns out to be bad you can with a box with av cable out connections on back just go into a rear input and bypass the tuner--leave set on that input and change channels with the box.
Let me know if you have questions and what you find---usually on this set if no signal---"unusable signal" will appear on screen if no signal.
Mar 20, 2012 | RCA F36665 36" TV
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Rca 20F514TD blue screen
Nov 05, 2009 | RCA 20F514TD 20" TV
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
We moved tv from living room to bedroom and the screen says "unusable signal"
Oct 05, 2009 | GE 31GT720 31" TV
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
