Question about Dryers
My maytag dryer MDET336AYW won't come on
I have a maytag dryer MDET336AYW that won't come on when I push the button. The light comes on when I open the door, but the dryer won't come on when I push the button.
  • 3 more comments
  • Shinecatcher Jan 04, 2009
    Ditto. Tried taping the two wires to the thermal switch together and cleaning the vent. Still won't come on.
  • Shinecatcher Jan 05, 2009
    I don't understand. Help.
  • angiedwardl Jan 05, 2009
    I don't understand either. Please explain. Thank you.
  • angiedwardl Jan 06, 2009
    We checked the belt and it is on and nice and tight. We pushed in the switch on the frame (the light goes off) and heard a click. The dryer still won't start.
    When I push the start button, I heard a ticking sound that sounds like a timer ticking (very soft). I pushed in start button and turned the drum with my hand while pressing the button that turns the light off, nothing happened.
  • 530 Answers
Probably have a back door switch. look and see if when you close the door it closes the switch
Posted on Jan 04, 2009
  • 1 more comment
  • erica graber Jan 05, 2009
    either you have a bad door switch or a broken belt. I believe to open the lid there are 2 clips located towards the top geta flash light use a putty knife or something similar. Turn the power off first. open the lid and you should see the drum if the drum does not have a black rope around it that means your belt is brken. if you do see the belt make sure that there is no slack and is nice and tight. if it's tight that is not your problem.
    There is a button when you open the door to the dryer look on the top around where the door meets the frame push it in and out it should click.
  • erica graber Jan 06, 2009
    do you hear the motor humming when you push to start? can you jump start the dryer by pushing the drum when holding the poush to start? be very carefull please... If you can you have a bad motor
  • erica graber Jan 11, 2009
    sounds like you have a bad timer. If you are hearing the timer after you are pressing start usually means that you have closed that curcuit. replace your timer.
Is there a reset button on a Maytag electric dryer purchased in 2000? Power is coming into the dryer, pushing the start button has no effect.
check the switch itself ,, you can do this with a meter and checking for continuity when the button is depressed, also check the door safety switch,, it won't run if this switch is defective,, you can check this one the same way , or just locate the connection, and add a jumper wire, to see if the machine starts
Aug 10, 2011 | Maytag Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't come on
and also change your cycling thermostat if your thermal fuse is bad chances are the thermostat is bad too
Mar 11, 2009 | Maytag Dryers
Dryer won't start
check your circuit breakers for dryer they may have tripped whenlights went out. write back if not the problem let us know a little more about problem
Jan 30, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Dryers Logo
231 people viewed this question
Top Dryers Experts
