Question about Samsung DVD-VR375 DVD Recorder/VCR
Does it need to be hooked up to anything else.
Does it need to be hooked up to any other devise to record a VHS to a DVD.
We have a bunch of VHS tapes we want to convert to DVD.
  • 10,594 Answers
No, its all alone DVD recorder VHS Combo, just put DVD-R and VHS tape and start burn DVD. What kind of problem you facing ?
Posted on Jan 04, 2009
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can you record on to a dvd from vhs on this devise
No, you can't because the DV2150 is a DVD player and not a recorder. You can record a dvd to the VHS tape.
I wish that I had better news for you.
Feb 26, 2011 | GoVideo DV2150 DVD Player/VCR
Can you record a vhs tape to a DVD
Yes,read ur owner manual,how to hook up before u can record and transfer from VHS tapes to DVD discs.
Oct 13, 2010 | GoVideo Go Video DVD/VCR Combo
Recording my VCR to my computer with a USB 2.0
the easiest way to do this is go buy a DAZZLE recording device and you can buy this anywhere like radio shack best buy. this will record what ever device you hook up to it and it wont take up a bunch of hard drive space. Very easy to use my wife even does it.
Feb 06, 2010 | HP Pavilion dv6000z Notebook
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
Jan 14, 2009 | JVC Everio GZ-MG20 Camcorder
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Samsung DVD-VR375 DVD Recorder/VCR Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
