Question about Watches
I wanna watch free porn on www.xvideos.com
U solve my problem fast hurry up
Hello i bought citizen jy0010-50e , the analog and the digital not matching up. when the digital on 12:00 the big pointer stand on 12, but the small pointer run to fast and standing min after .
it sound like you have motherboard problem, or mechanical problem - unfortunately neither of this can be solved at home, in most countries citizen offers 5year warranty on these time pieces, usually warranty is handled by the seller.
call your seller, obtain ra and then send it back...
Apr 05, 2015 | Citizen Watches
TAG watch is running fast
You need to find a qualified watchmaker to correct this problem.
If the movement was replaced twice the same problem would not be happening again and again unless there is something you are doing that puts the watch in some kind of field to magnetize it or the place you took it to did not really do anything.
My guess is they did not do anything since you say they oiled the crystals. Just oiling a watch will not solve this problem. A qualified watchmaker would know this.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 11, 2010 | Watches
How do you turn off the beeping sound while using the calculator?
Go to calculator mode. Press the lower of the two silver buttons on the right.
Jan 07, 2010 | Casio New CASIO CA-53W Water Resistant...
Watch has been running fine, now running fast.
HI there,
If you have an Automatic Wrist watch. Some adjustment has to do inside the watch. You better bring the unit to any local watch repair shop to adjust or correct the polarity of the energizer.
Hope this helps.
micro
Jul 28, 2009 | Watches
Pocketwatch runs fast
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
Jan 26, 2009 | Geneve Watches
Breitling problem
This usually occur when the hairspring is disturbed ( some grease, dust particle, etc). Can be magnetized as well.
You need to find your nearest watch repairer and ask to overhaul your watch. After that it will run like new.
Jan 03, 2009 | Watches
Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
Oct 04, 2008 | Breitling Aerospace 455 Wrist Watch
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Sep 05, 2008 | Festina 161625 Wrist Watch
Moisture
After 5 years all of the case parts must be replaced i.e.,gaskets and crown then the watch must be pressure tested. anyone who is autherized woulod know that. contact Tag to have the matter resolved
Jun 05, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Watches Logo
211 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
