Question about Prenco 2002 - 2006 Cadillac Escalade Ignition Coil W0133-1687022 Cad
High beams wont stay on - Prenco 2002 - 2006 Cadillac Escalade Ignition Coil W0133-1687022 Cad
    Top Expert:
  • Prenco Master
  • 76,132 Answers
More than like the high beam switch is defective. To replace it do the following video. You have the same basic switch as the Chevy Sierra trucks so watch the video below.
Posted on Nov 05, 2012
While low beams on the left high beams stays on dim light but wen I turn high beams on they work fine
It could be driving lights mode instead of low beam. Check connections.
Jun 16, 2017 | Cars & Trucks
How to correct a 2005 chevy monte carlo high beams from staying on
About 17,700 results (0.74 seconds) Search Results
    My high beams won't go off!! - Monte Carlo Forum - Monte Carlo ...
    montecarloforum.com > ... > General Forums > General Monte Carlo Talk
    Jun 8, 2012 - i flipped on the high beams last night and i think that switch in the column broke. ... My high beams won't go off! ... 2003 Chevrolet Monte Carlo. Help!! Need to get headlights working. - Monte Carlo Forum ...
    Jan 1, 2012
    Repair Guide: List of Common Monte Carlo Problems and Solutions ...
    Aug 9, 2011
    Fog lights not working, High beams stay on?
    May 9, 2011
    More results from montecarloforum.com
Jan 30, 2016 | 2005 Chevrolet Chevrolet Impala LS
High beam light wont stay on
Suspect dip switch requires renewal
Oct 10, 2014 | 2001 Dodge Intrepid
Why wont my high beams stay on by it self after i let go of the switch. on my 2001 buick regal
High beams are on by pulling the lever toward you temp mode to engage the high beams simply push the lever forward the high beams should engage then.
Sep 23, 2014 | 2001 Buick Regal
HEADLIGHTS WONT TURN OFF WITH SWITCH ON A 2002 FORD ESCAPE
Do they stay on with high and low beam? If high or low beam make a difference then you likely need a multi-function switch. If they stay on regardless of high or low beam your Daytime Running Light Module (DRL) may be faulty. It should be located on the rad support, ahead of the radiator. Once you located it, unplug it and see if your lights go out. If they do, replace the DRL. If they do not you likely need a headlight switch.
Jan 26, 2014 | 2003 Ford Escape
High beam wont stay
do you push or pull the turn signal combo switch for the high beams? If you pull it towards you, try pushing it away from you. If neither stays on, the switch needs to be replaced!
May 25, 2013 | 1994 Toyota 4Runner
My daytime running lights work, high beams will come on but switch wont stay on, have to hold it. Low beams do not work and daytime running light dash indicator stays on all the time. Is it a relay or...
if you have to hold the switch so the high beams stay on then that indicates a bad/worn switch,you could have 2 problems the day time running light relay may have a problem with it.i would first replace the headlight switch at the base of the steering colume as by the info you supply its not changing to the high beam side without holding the switch in position.
May 25, 2011 | 1998 Pontiac Sunfire
Day time running light and low beams stopped
I would say your light switch is either dirty or bad.
www.rockauto.com
Feb 04, 2010 | 2000 Chevrolet Impala
1998 VW Beetle high beam wont stay on
This could be a bad switch or the relay. I hope this helps.
Oct 22, 2009 | 1998 Volkswagen Beetle
Prenco 2002 - 2006 Cadillac Escalade Ignition Coil W0133-1687022 Cad Logo
Top Prenco GPS Experts
Are you a Prenco GPS Expert? Answer questions, earn points and help others
