Question about Cozy Heating & Cooling
Need to buy a thermocouple - Cozy Heating & Cooling
    Genius:
  • Cozy Master
  • 1,033 Answers
Hello, most hardware stores or HVAC supply stores carry thermocouples.
Posted on Nov 05, 2012
Listing were to bye a thermocouple &how much
You can buy a thermocouple at any HVAC supply house. Thermocouples are fairly inexpensive and are usually priced around $10, but prices can change based on the specific product requirements
Aug 05, 2016 | Heating & Cooling
Bernzomatic ph3200c thermocouple
Try ebay, amazon or you can use a generic one. Just ensure the thermocouple is secured properly in the area of the pilot flame.
Nov 13, 2013 | Pool & Spa
Maybe it sound strange but does anyone know where I can buy a thermocouple online?
Don't worry, it's not strange. I've also done some research into thermocouples. I came across a website that specializes in them;
Good Luck with your search
http://thermocouple-online.com/
Jan 28, 2013 | Plumbing
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 28, 2012 | Rheem Water Heaters
I can not light the pilot on my reliance sta-kleen 502 (30 gallon) waterheater. please help
Reliance is Rheem
Replace thermocouple is best start point.
Example Whirlpool manual shows general replacement steps on page 22:
Buy thermocouple at hardware or home center. measure length before going to store.
http://waterheatertimer.org/pdf/Whirlpool-6510397.pdf
Utube videos show how to replace thermocouple
Many things can affect pilot:
Low gas pressure, Water or air or debris in the gas control valve, High-heat event causing ECO to trip requiring new gas control valve, burner and tubes needing clean-out, FV sensor tripped, loose or bad thermocouple.
Manual above shows general steps for doing some of these things, but service technician is probably best choice if thermocouple does not fix problem.
Gas water heaters require periodic maintenance.
If repairs cost more than $330, then buy new gas water heater and install yourself.
Use the old one for a solar collector.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | RELIANCE ELECTRIC WATER HEATER
My reliance sta-kleen 502 gas water heaters' pilot will not lihgt. can some one give me an idea what to do.
Reliance is Rheem
Upvote the help.
Flame of water heater does not light up
You need to replace you thermocouple its the tiny copper in color probe going into water heater. This componet works of milli volts and keeps the pilot lit when this goes bad the pilot goes out. Heres what you need to do shut gas off take all fittings off gas valve thats the thing with the knob on it to set water temp. pull out manifold and remove thermocouple by pulling at the base straight out. You can buy replacement thermocouples at your nearest hardware store.
May 11, 2011 | Heating & Cooling
I have a William Furnace model #1403622 and the pilot won't stay lit. I keep reading it may need a new thermocouple but where do I buy it and how much does it cost.
Hello, you can buy a thermocouple at any heating and cooling store, they cost between 7 and 15 dollars depending on the length of it.
Mar 25, 2011 | Williams 1403622 Gas Compact Heater
I have been told that I need to buy a new gas fire because the thermocouple is not working and needs replacing.Unfortunately the fire is approx 10-12 years old and no longer made hence the heating engineer...
I think before I went to the expence of buying a new fire place I would remove old thermocouple and take it to a heating equipment supply house and see if they can find a replacement. Most equipment manufactures don't make their own controls, such as thermocouples,gas valves ,sensors and other equipment. Many chain stores such as true value have good knowedgable people and if they don't have what you need they may know someone that does. I hope this helps you. thanks
Nov 09, 2010 | Heating & Cooling
I want to know where to buy a thermo coupler for an All Pro SPC 150.
Thermocouples can be purchased at most hardware stores, home depot, etc. The only difference for a thermocouple is the length. There are heavy duty types and regular. I would suggest using a heavy duty thermocouple. Also, it is recommened that thermocouples be changed every 2-3 years to prevent unnecessary failures, which usually occur when you need the unit the most.
Nov 12, 2009 | All-Pro Heating & Cooling
Heating & Cooling Logo
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
