Question about KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher No response from wash buttons
No response or lights from Heavy, Normal and Rinse buttons when pushed. Did reset ie:sequence of keys within 7-8 secs. hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry, afterwards all lights flashed and seemed to try to run a cycle with wash and rinse lights alternateing on and off. After that completed, tried to hit wash buttons again but No response or lights again. I also checked the hoses to the Fill Valve Assy and dont appear to be clogged.
There is water on the bottom after a full cycle.
Water at the bottom of your dishwasher after a wash cycle indicates a drain issue. Please check out my quick tip on how to fix this issue.
http://www.fixya.com/support/r7229617-quickest_way_fix_drain_issue_dishwasher
Please rate me "4 thumbs" if that was helpful.
Dec 15, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher seems to run for a very long time on normal cycle. It leaves a whitish residue on dishes and the glasses appear cloudy. I do use a rinse agent.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 21, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My Kitchenaid dishwasher is acting up. Everything else works but when you push the start button it will not start. model # KUDM01TJBT0
What happens when you try to start ?Do you get any lights blinking?Do your hear any motor turning ?What happens?
Sep 09, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
May 16, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Machine not emptying properly
heatman101
Jan 06, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Normal cycle button blinking, cannot start new wash cycle
Press Heated Dry, Normal, Heated Dry, Normal buttons in sequence within 6 seconds to reset control. Could also be locked. Press and holding the air dry button for four seconds.
Nov 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid Dishwasher Rinse Aid Clogged w/ Detergent
have you tried distilled vinagar? this may work for you.
Jul 29, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Hotpoint dwt10 not working rinse aid light flashing
I have DWT10P dishwasher.It is displaying two rapidly fashing E lights (Fast & Delicate )wash cycle.Can you tell me what its mean?
Mar 24, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
