Question about Dometic Rooftop RV Air Conditioner
Where is the fan limit switch on a model 66012-041 duo therm furnace
  • Dometic Master
  • 6,674 Answers
Here's a good link for you, where you can download a PDF manual for that furnace. The limit switch is normally near back of unit attached to or close to heat chamber. Follow wires that run toward the rear. One will go to one side of limit switch, other will be coming back.
http://bryantrv.com/docs2/docs/operating/dt6600.pdf
Posted on Jan 27, 2013
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Posted on Jul 19, 2008
motor1258
  • 6674 Answers
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Posted on Aug 14, 2008
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
ad1media
  • 7 Answers
SOURCE: duo therm AC/ furnace in Puma not kicking on
there is a "control unit" inside the bottom cover of the A/C on your cealing ... inside there is the control box that controls itself. Has a silver peice bout 2'' thick and the size of a quarter this is your freeze control, if your A/C gets TOO cold and might damage itself it kicks on and shuts down your unit(yes even your furnace) need to have a tech come out and fix/replace it, RV Tech, most A/C repair companies know NOTHING about RV's
Posted on Jan 03, 2009
  • 68 Answers
SOURCE: mal functioning thermostat on duo therm model 620215
Ok;
Upgrade kit Part# 3307713.010
Price is 274.75 Plus shipping
Can be purchased from any Dometic dealer or I have an ad on this site. Coach Tech RV
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
It is 9 degrees outside and my duo therm furnace is blowing cold air
I hope you have fixed it by now. Probably was the limit switch? don-ohio
Dec 18, 2016 | Heating & Cooling
Why heater fan will not come on?
Wish I knew how old your furnace is. Let me answer your question directly. In the heat mode the fan runs independently from the air conditioning fan relay. Its either brought on by time or temperature. An old furnace will use a fan and limit control that uses a coil to sense the heat exchanger temperature and turn the fan on or off. Newer furnaces use a timer on a circuit board. 20 years or newer Ill bet its a timer board. Follow the blower motor wires back to the component and ill bet that's the culprit. Hope it helps. Good luck.
Oct 12, 2014 | Heating & Cooling
Duo- Therm furnace
turn the temperature knob
Nov 21, 2013 | Heating & Cooling
Furnace refuses to cycle off even when room is 20 degrees warmer than setting
Do you know how to access your furnace wiring ? What make/model furnace?
Jan 18, 2013 | Dometic 3109228.001 Duo Therm Comfort...
Dometic Rooftop RV Air Conditioner Logo
164 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
