Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
My kenmore 3.5 front loader is still half full of water when I open the door after cycle completes. only happens on certain cycles like normal and perm. press. does not occur on quick wash
Floods my utility room with water when I open the door.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 05, 2012
  • blh454 Nov 05, 2012
    hey Richard! it is model #417.44052401
  • Richard Roth
    Richard Roth Nov 05, 2012
    First you will need to open the unit up and pull the drain boot from the tub to the drain and check for a partial blockage. Post back if that is clear.
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Posted on Feb 08, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 1294 Answers
SOURCE: kenmore front load washer wont drain gives F2 error
There is an awesome guy on fixya with this:
http://www.fixya.com/support/r622155-kenmoreelitewhirlpoolduetdoorjammed
http://www.fixya.com/support/r615354-fherrorcodewhirlpoolduetkenmore
Posted on Mar 28, 2009
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
How do i get rid of mold in my washer
If top load, run a washer full long cycle with out clothes and a full cup of Clorox. If a front loader, do the same thing, but then open door after the full cycle is complete. Front loaders are sealed and there is nowhere for the moisture to go..
Jan 22, 2014 | Kenmore Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
HI, i have a zanussi FJDR1466s washer which is now 7 years old and i have grey lines on washing after a wash also there is grey grunge in the door seal. Can you tell me what i should do to correct this...
Hello, W/D here.
We use bleach to clean the washer from time-to-time.
1. Mix bleach 50%50% with water, and wipe the door seal and bellows liberally.
2. Pour the remainder in the tub, along with one additional cup of straight bleach.
3. Fill all of the dispenser cups with bleach.
4. Run the hottest cycle available for your machine, and the hottest rinse cycle available. For our machine, this is the "sanitary" cycle.
5. When this cycle has completed, run a regular cycle to purge out any residual bleach.
5. Leave the door open between wash loads. This allows the moisture to evaporate, and keeps the mold from developing. This wasn't ever an issue with top loaders. Most people left the lid open! It's more of a problem with front loaders; there are more places where water can collect and pool.
IF you don't get relief by performing the above steps, you may have to replace your bellows seal (the part between the door and the tub). I have seen where some folks' smell problem just won't go away, and that's how they cured it. Normally, the bleach wash and leaving the door open will do the trick. You may even have to do this several times to get the full effect, but it's worth a try, and is much less expensive than replacing a bellows. Like I said, it usually works.
Best regards, --W/D--
Feb 07, 2011 | Zanussi FJS1225W Front Load Washer
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Washer is not draining at end of cycle-puddle in washer at end of cycle -sears kenmore front loader 3 yrs old
Some of that is normal, if you turn the drum around you will here water. Mine do it also.
Feb 13, 2010 | Kenmore 44102 Front Load Washer
Washing machine won't go to next cycle (rinse0
Its the lid safety switch. the top of the machine should pop loose with a yank on each front corner one at a time then it should hinge up enough to see what has happened. the switch may have broken or the connector has come off. Good luck
Aug 24, 2009 | Washing Machines
Soap left in clothes
hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
Jul 15, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
