My sharp lc 32d59u won't come on. power button is red. dont know what is wrong
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
sethdileswar
  • 253 Answers
SOURCE: switch on tv..red light blinking on power n sleep mode button.
change your picture
Posted on Apr 06, 2010
  • 713 Answers
SOURCE: the power indicator of my
CHECK FUSE CHANGE FUSE.
Posted on Feb 15, 2011
  • 11800 Answers
SOURCE: sharp lc-19sb225u tv turns on with a "white noise"
The blue screen means the processor of the tv no longer finishes the loading of the firmware - hardware fault, either the chip that stores the firmware or the processor have failed.
Since the chips are soldered on the mainboard and cannot be removed separately that means that the entire mainboard will have to be replaced. This is it
http://www.partstore.com/Part/Sharp/Sharp/LC19SB25U/Sharp/Sharp/DUNTKE352FM02/New.aspx
Now you must decide if it's worth paying $400 for a replacement board or it's better just to buy a new tv - i'm for the second option.
Posted on May 17, 2011
Sharp AQUOS won't turn on, how do i fix it? You can tell the TV power is on but the picture is a black backlit screen, none of the menu options work. Any assistance would be greatly appreciated!
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 04, 2015 | Sharp LC-32D59U AQUOS 32 In. 720p LCD HDTV...
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
What are all the pieces to a lc 32d59u
Panel, Bezel, Rear Cover, Stand, Stand Support, Main Unit, Power Unit, LCD Control Unit and Inverter.
May 02, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
Sharp lc-22sv6u won,t power on. no green light.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
No red light no power
the probability is you have a bad power supply board. have the set checked. They need to see if the standby b+ is present.
Feb 13, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
