Question about Petzl Tikka Plus
Open tikka plus battery compartment - Petzl Tikka Plus
3 Suggested Answers
  • 75 Answers
SOURCE: Petzl Tikka Plus Headlamp has a short and is eating batteries
There's really not much that's serviceable in these things. Try cleaning all the terminals again but this time use VINEGAR instead of alcohol which does not neutralize the corrosion as vinegar does. Just dip a q-tip in the vinegar and swab it on the terminals, then with a dry one, swab up the excess. Then install all NEW batteries, do not mix old ones with new ones as the new ones cannot make the old ones work any better than they are used. If they still don't work, welome to the world of cheap products that are intended to be tossed when they quit functioning. Good luck. :)
Posted on Apr 24, 2009
SOURCE: Petzl tikka plus torch repair
I understood that fixya was free from reading the word free all over the place. I wasted my time filling in the form to find out it was not free, but only 7 days free trial but you needed credit card details before. I will not be the first to write this and am tired of being told things are free when they are not. Do not mislead people.
Posted on Jan 06, 2010
How can I change battery?
  • Open battery compartment
  • Remove old battery
  • Install new battery correctly
  • Close battery compartment
Mar 18, 2016 | Wahl Sterling 2 plus Hair Trimmer
How do i remove the battery from porsche 928
Remove rear carpet. Remove spare tire in recessed tire compartment. There will be a small hatch with a plastic white lever that you have to swing open. Once the door is open, remove ground (black) first, then the positive red side. Clean terminals and also clean ground to rear hatch from battery.
Oct 06, 2014 | 1986 Porsche 928
How to remove batteries from TI 84?
Turn the calculator, open the battery compartment at the bottom, remove the batteries.
Jul 02, 2014 | Texas Instruments TI-84 Plus Silver...
Where is backup battery on ti-84
Open the battery compartment. Above the four AAA batteries you should see a small screw. Unscrew that to uncover the backup battery.
Jun 05, 2014 | Texas Instruments TI-83 Plus Calculator
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
Jan 05, 2010 | Petzl Tikka Plus
Facewest quiz
I believe you are looking at power settings, range compairson
Nov 11, 2009 | Petzl Tikka Plus
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    Apr 19, 2009 | Petzl Tikka Plus
    Petzl Tikka Plus Logo
    56 people viewed this question
    Top Petzl Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
