Question about Maytag Performa PAV2200
Maytag Performa leaks
It just leaks water.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Remove the 2 screws on the front panel and remove the panel. Run a cycle and look for the leak. Post back your findings.
Posted on Nov 05, 2012
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
  • 148 Answers
SOURCE: Maytag Performa water level
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Jul 13, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a Maytag (Performa)
Searspartdirect.com carries all the major brand names. Just type in your model number in the search menu and use the exploded view diagrams under the various parts headings on the next page. If you do not wish to order on line, or wish to use another website, use the part number provided on the Sears website. Maytag identifies some of their parts by different series. If the part you need is listed this way and you are confused, please post back and I can assist. Make sure you provide your model number for me. I hope this helps you.
Posted on Aug 12, 2008
WRMtech
  • 70 Answers
SOURCE: leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Posted on Feb 24, 2009
lavon82931
  • 17 Answers
SOURCE: washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Posted on Sep 14, 2009
My Maytag Performa Dishwasher is leaking when doing the dishes...
Sounds like your fill valve is stuck in the filling position...see if you you have water standing in it a couple hrs after a drain cycle. if it does then the valve needs to be replaced or you can take it apart carefully,(there is a sping that might fly out and get lost) and clean it. Mine had some small trash in it from the city water line.. The left side has an over flow hole is where your water is coming from..
Nov 12, 2009 | Maytag Performa PAV2200
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Washer overflowed, water all over the floor, any
Sep 14, 2009 | Maytag Performa PAV2200
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Water leaking from back
There might be a small hole in the inside part of hose, or ck fill valves
Oct 21, 2008 | Maytag Performa PAV2200
Hi jamac74
The leak could be comming from one of 2 places, either the pump or the main seal. the best way to find wherer the leak is comming from is to take the front panel off. you can do this by poping the top up there is 2 clips that hold the top down. use a putty knife to pop the top up then there is 2 screws holding the front on.
Sep 16, 2008 | Maytag Performa PAV2200
Jul 13, 2008 | Maytag Performa PAV2200
MAYTAG PERFORMA is leaking
the bearing and seal are worn and leaking. if the machine is a good oe and the repair cost is reasonable, i would have it repaired. contact your local repairshop and determione the cost vs replacement of machine
Nov 16, 2007 | Washing Machines
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
