Question about Sharp R-7A85 Microwave Oven
I need a manual for an RV Sharp Microwave/ Convection R820
5 Suggested Answers
SOURCE: Sharp Microwave/convection oven
We had the same problem, and the service technician quoted over $300 to fix it. My wife found this thread online (click on link below) and after following the advice here ours is now fixed for a total cost of under $40, and that included a new soldering iron (see below)!
http://www.fixya.com/support/t902145-sharp_r1870
The problem is either the damper motor or the damper switch. You can order both from Tritronics and ours shipped un less than a week. It is not possible to tell which it is without disassembling the microwave, so I ordered both. In our case it was the switch (one of the electrical contacts was black like it had burned out).
Read all the advice about discharging the capacitor; I would recommend downloading and printing out the service manual (especially page 18 which is an exploded parts diagram which helps you identify what is what (click on link below)
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
Page 14 is also useful because it gives you the part numbers to order from Tritronics. The two items you may need are 1-11 Damper switch and 1-22 Damper motor.
The space is rather tight, and you need to be very careful you don't cut your hand on the sharp (no pun intended) metal. It definitely helps to remove the long mounting bolts that runs through the space. Be very careful when disconnecting the electrical connections: the little metals tabs they use on the ends of the wires break very easily - hence the soldering iron. The most difficult piece is undoing the screw on the right hand side that secures the motor; it's just cramped and you need a very small/short phillips screwdriver to get to it. I would advise removing the switch first (it's secured by a couple of little metal tabs) because then the cam which drives the damper door will be able to drop free when you remove the motor. Finally, when installing the new motor, make sure that the tab on the cam wheel is correctly inserted into the little slot on the bottom of the damper door.
As I said above, read all the advice on the other thread and the general advice on working around microwaves on the http://www.microwavedisplay.com/ web site. It's all good stuff. Good luck!
Posted on Dec 23, 2008
guru_dev
  • 315 Answers
SOURCE: need manual
Here you go: http://common.csnstores.com/common/marketing/1870_operation_manual.pdf
Posted on May 05, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
  • 19 Answers
SOURCE: Sharp R820BK 900 Watts Convection Microwave Oven
you can get the manual in this link
http://kitchen.manualsonline.com/manuals/mfg/sharp/r820bk.html
Posted on Jul 29, 2012
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
I need a cooking manual for a Sharp Convection Microwave model R820BW
If you go to the Sharp web site and download the manual, or part you want, there are a few recipes in there, and it looks like they have an offer for a convection cookbook inside the manual.
Mar 16, 2014 | Sharp R-7A85 Microwave Oven
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Oct 28, 2009 | Sharp R-353 Microwave Oven
Aug 30, 2009 | Sharp R-7A85 Microwave Oven
Sharp R-1850A Mocrowave Convection - No power
Chances are if the internal fuse and magnetron thermostat are good, then you have a circuit board that needs repair.
You can probably find exploded views at the Sears parts site. If you find a bad thermostat, the best place to order Sharp parts is Tritronics.
We regularly repair these control panels for customers nationwide (RV owners & dealers, too) with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 18, 2008 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
