Question about Frigidaire GLMB209D Microwave Oven
No power i have a frigidaire over range microwave and it lost all power. it had a loose door switch but would work if i held on to the microwave door during cooking, then the door switch fell out of its holding spot and i then lost all power. nothing works or turns on please help. Thanks.
    Sergeant:
    Champion:
  • 338 Answers
You will need to replace the 20amp fuse above the control. also obviously fix the door switch. which can all be accesible through the control panel
Posted on Jan 04, 2009
Frigidaire FMV158FMB power issue
Sounds like the door latch switch is broken and shorting out.
Feb 20, 2014 | Frigidaire Microwave Ovens
Lost all power
Door switch is bad or a fuse blew out inside the microwave cover housing. Switch is most common.
Feb 06, 2014 | Sharp R-1480 Microwave Oven
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
Microwave not working unless I hold & push up the door. what's wrong?
You have a defective bottom door switch or possibly its mount is loose.
The service manual is here.
Also see my help file on door switches here.
May 31, 2012 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
I have a Frigidaire Microwave oven CFMV156DBA. The clock, lights and the keypad works. The turntable does not turn and it does not heat
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Apr 26, 2010 | Frigidaire FMV156D Microwave Oven
Frigidiare over the range microwave problem?
It depends on whether it is an obvious sagging of the door but I suspect the safety switch inside of the housing may simply need adjustment.
I don't know how much hassle it is to uninstall the box from its OTR position but the housing itself shouldn't be difficult to remove and once the housing is off, you may be able to see the door switch well enough to ind if it has any range of adjustment. If the door switch is made as many, it may have a metal 'leaf' actuator that can be bent slightly to put the leaf back in the path of the door.
If the hinge is somewhat weak by design, then replacing it and doing nothing else may not be a very permanent 'fix.'
It's unfortunate that the structure of the unit's housing design is so poor as to allow something this primitive to happen.
Mar 24, 2010 | Frigidaire FMV156E 950 Watts Microwave...
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
My Frigidaire fmv156dsb microwave counts down and lights work onl
That would be a bad primary interlock (bottom door switch) or its mount may be, loose, cracked, or misaligned.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Aug 06, 2009 | Frigidaire Microwave Ovens
Door switch went out- second time in two and a half years.
sounds like the door switch has been used to stop the unit while heating instead of using the stop button.
Phil
Jun 10, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
Frigidaire GLMB209D Microwave Oven Logo
369 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
